tire size on stock GSL
Old Jan 17, 2002 | 06:09 AM
DONNA's Avatar
what size tire can i go to on a stock 13 inch whell and it not rub,,,,
Old Jan 17, 2002 | 08:23 AM
error402's Avatar
#!/sup_mod/üb3rg33k
i'm curious too. :waits:
Old Jan 17, 2002 | 08:35 AM
RXcetera's Avatar
EliteHardcoreCannuckSquad
205/60... they'll only rub when you go full lock. The wait is over .
Old Jan 17, 2002 | 08:36 AM
error402's Avatar
#!/sup_mod/üb3rg33k
*happy little dance*
Old Jan 17, 2002 | 11:01 AM
rotorhead's Avatar
i've got 205/60 13's with no rubbing whatsoever. i'm also using eibach springs(1"drop). i looooove the wider tires!
Old Jan 17, 2002 | 12:45 PM
peejay's Avatar
Old [Sch|F]ool
the 205/60's fit OK on the factory 5.5" waffles on the SA, and had no fender clearance problems whatsoever and were a good half-finger away from the struts.
Only problem is that 205/60 is kinda fat for such a narrow rim. There isn't enough sidewall support and the tires can buckle under easier. This can be fixed somewhat by cranking up the pressure but then you'll wear out the center of the tread in about 5k. I found I could get best wear by running 22-24psi in the front and 20-22 in the rear, but then it would feel kinda sloppy when on transitions... but I tell ya, that thing was like a kart around hard corners, with such low tire pressure the tires didn't grip and it was VERY progressive, go through corners in a true 4-wheel drift (not "drifting") with ease.
I also have 205/60 race tires on 13x7 wheels with a zero offset. These have about an INCH or more of strut clearance, stick out a lot more than factory wheels. They pulled the front fender lips out once when I hit a rut at 60 or so MPH but the suspension nornally doesn't compress that far. (Who in their right mind would put a rut in the infield? )
Old Jan 17, 2002 | 02:46 PM
I run 205/55/14 on the f. 225/50/14 on the rear with no prob. Toyo RA-1's and this car is pushed hard around solo 2 and track days.run 205/60/13's on my street car with no prob.
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
