Microtech Very inaccurate map sensor readings..
Old Sep 5, 2005 | 09:25 AM
Spooledup300z's Avatar
I run a Lt4/Mt4 and the problem im having is very inaccurate map sensor readings. The engine can be off and the ignition can be on and the computer shows 5psi. I took my car to the track about 3 wks ago... i was running 11psi but eh computer was reading 25psi which made it run crazy rich(bogging, misfiring etc...).
I sent the computer back to microtech(AUS) so they can check it and all came back well, they said for me to check my wiring. I went over the wiring for the map sensor about 10x and all is well. I even replaced the map sensor and same exact **** is happending.
Im to the point where if theres anyone Close to MD,PA,NJ and have a little time on there hands or is travling my way i'll pay someone whose familiar with the microtech to check over it and tell me whats wrong.
Would tps calibration have anything to do with this? Its calibrated right, but im to the point where im willing to try whatever to fix it.
Lee
Old Sep 5, 2005 | 05:56 PM
10sec rx7's Avatar
is it a external map sensor??
Old Sep 5, 2005 | 08:43 PM
yes external
Old Sep 5, 2005 | 11:03 PM
BOOSTED Vert
do you still have the internal one ?
Old Sep 6, 2005 | 06:14 AM
the new MT/4 never came with an internal map sensor... only external plug for a 3bar
Old Sep 6, 2005 | 06:18 PM
10sec rx7's Avatar
i would say you have a 2 bar sensor not a 3 bar sensor
Old Sep 6, 2005 | 07:23 PM
Give me some part #'s 3bar#, 2bar#.. and what your saying is the system uses a 2bar not a 3bar? or are you saying the system uses a 3bar and i have a 2bar map instead of a 3?
please explain.
Weather its a 2 bar or 3bar it still should read accurate right?
Old Sep 6, 2005 | 08:53 PM
TonyTurboII's Avatar
Glock Lover
Not past 14 psi
Old Sep 6, 2005 | 09:13 PM
Originally Posted by TonyTurboII
Not past 14 psi
my problem is all over the map readings
Old Sep 7, 2005 | 06:48 PM
10sec rx7's Avatar
please explain.
i dont have any part numbers handy,
you have a 2 bar and your suppose to have a 3 bar,
no it wont be accurate, 2 bar only reads to 14.7psi and 3 bar to 29.4psi
Dale
Old Sep 7, 2005 | 09:32 PM
Dale
ok dale.. but would that make in inaccurate at idel and even when the hey is on engine off read 5psi.?
if its a 2bar and not a 3bar then it would be inaccurate only after 14.5psi?
meaning anything under 14.5psi it would read fine and be dead nuts?
Old Sep 10, 2005 | 04:05 PM
jimmyv13's Avatar
Round&Round not Up&Down
Where are you getting your MAP source from?
Old Sep 10, 2005 | 09:29 PM
10sec rx7's Avatar
think about it
0-5v sensor,
one is calabrated to read from -30 to 14.7psi
one is calabrated to read from -30 to 29.4psi
of couse it will be out and wont read correctly...
you have the wrong sensor, get a GM 3 bar, same as what a haltec uses and it will be fine
Old Sep 11, 2005 | 02:35 PM
the front of my intake
Old Sep 11, 2005 | 02:37 PM
think about it
0-5v sensor,
well whats the gm 3bar map part #?
Old Sep 11, 2005 | 05:53 PM
10sec rx7's Avatar
i dont know, i never buy them, i ALWAYS got supplied a 3 bar sensor when i purchased a 3 bar ecu....
do a search you will find your answers
Old Sep 11, 2005 | 08:59 PM
Well 10sec Rx7, I must say you are right, i did a little searching and i found out i have a ******* 2bar map sensor instead of a 3bar. Heres the site i found to help people identify there map sensors http://www.robietherobot.com/Storm/mapsensor.htm
Im gonna get a 3bar from GM tomorrow and hopefully that fixes the inaccuracy. Im sure it will since i have the wrong sensor
Old Sep 11, 2005 | 11:59 PM
jimmyv13's Avatar
Be sure it's the bottom nipple.
Old Sep 16, 2005 | 09:55 PM
You were right 10sec rx7, i had the wrong map sensor the thing reads dead nuts now. HAH I gotta retune the whole things now since its so accurate \\
I just wanna say thanx to all that helped me
Old Sep 25, 2005 | 03:18 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
you're joking?
Old Sep 26, 2005 | 08:22 PM
yah... its right at the back of the intake
i mistyped
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
imitek
24
Dec 1, 2015 03:35 PM
mulcryant
Sep 9, 2015 05:24 PM
befarrer
Sep 4, 2015 08:26 PM
