Microtech Increased Engine Cranking time after MT install?
Old Sep 2, 2005 | 09:14 AM
buzz2's Avatar
I've noticed that the engine is required to crank longer before starting, since installing my LT10. Is this common?
Thanks,
Buzz
Old Sep 4, 2005 | 12:49 AM
BOOSTED Vert
yea, it doesnt engage the trailling coils during cranking. Which means that if your engine has less than perfect comp. itll take a bit longer to start.
Old Sep 9, 2005 | 07:39 AM
fastcarfreak's Avatar
3rd motors a charm I hope
mine takes a bit too, seems to be normal for a lot of microtech users. It could also have something to do with the idle air control not being controlled by microtech.
Adam
Old Sep 10, 2005 | 01:01 AM
BOOSTED Vert
Adam
Well, I have everything blocked off... And it sucks..I noticed that it only happens when the car is off for a long time. Once I crank it, everyother time after that it cranks like normal.
Old Sep 10, 2005 | 01:58 AM
myfc3s's Avatar
That's what she said...
Same with mine^
Old Sep 10, 2005 | 04:22 AM
Infini IV's Avatar
Microtech Tuning!
Takes awhile to setup your crank parameters. I messed with my water temp correction map (I think... kinda forgot which map), and after a couple days messing with it, I got my car to start after turning over once or twice. BTW, I'm in SoCal, so weather doesn't change much in this area from season to season.
befarrer
Aug 14, 2015 04:18 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
