FD Best brake Pads? (inyour opinion)
Old Aug 18, 2005 | 07:49 AM
recon fd's Avatar
semper Fi
Talking Best brake Pads? (inyour opinion)
First off I know nothing about the best brakes, so if anyone could clue me in that would be great. Also is this a good deal?
FS: Hawk HPS front pads
40 bucks
Disclaimer: chances are something in my post will be spelled wrong, since I am teh suck at teh spelling (and grammar/punctuation). Please refrain from pointing these mistakes out to me as I will not learn from my mistakes.
Thanks for the help
Old Aug 18, 2005 | 08:01 AM
alloyboy's Avatar
FD3S OWNER
EBC redstuff are the 1's for me
Old Aug 18, 2005 | 08:02 AM
NCMontegott's Avatar
This is your exit
yeah i use EBC Green stuff, i went with them because they are supposdley ( i know miss spelled) no as hard on your rotors but the greens do have a little squeak at low speeds when they are cold.
Old Aug 18, 2005 | 08:03 AM
Sgtblue's Avatar
Urban Combat Vet
You might want to search in the "suspension/wheels/tires/brakes" section. I'm getting ready to order up a set of BONEZ STAGE 1's.
Old Aug 18, 2005 | 08:08 AM
recon fd's Avatar
semper Fi
Has anyone replaced the stock rotors with a rotor the same size. I didn't know if everyone went with a bigger brake package when it was time to chang the rotors. What did you use if you didn't go bigger? Did you buy a package from somewhere? Just fishing for info about brakes. I don't want to go bigger, jsut want to chage my pads, and possibly rotors.
Old Aug 18, 2005 | 08:09 AM
ArcWelder's Avatar
Might want to try posting this in the Tires/Wheels/ brakes section. First off, there is no best brake pad. To help answer your question you have to give alot more information. Such as, intended use, dusting issues, price, performance...
The second question, is $40 a good deal on these pads, the answer would be no if they don't fit your needs.
40 bucks
Thanks for the help
Old Aug 18, 2005 | 08:18 AM
recon fd's Avatar
semper Fi
I guess you missed the IN YOUR opinion part. I guess I need to restate this for you, "So for YOUR FD, what type of brake pads do you use?" Is that better for you? And I figured that this post should have been put in the tire/brake area the first time I was told, but it's here now so all I am asking for is your help. Thanks
Old Aug 18, 2005 | 08:33 AM
Mahjik's Avatar
Mr. Links
No, what he is saying is that there are pads out there for specific use. i.e. the pad one person chooses SHOULD be based on car use. Trying to use a street pad on the track or a track pad on the street just won't work. Other concerns are dusting, etc..
So, first, post up what you intend to do with your car then people can help you select a good pad.
Old Aug 18, 2005 | 09:08 AM
ArcWelder's Avatar
No offense meant on my part. Sgtblue's post to try in the wheel/tires/brake section was posted 6 minutes before mine while I was still composing.
For my car on the street the stock pads were fine. Low dusting, worked well when cold, but they're not cheap. Track I've used Hawk Blues and Performance Friction 93's and 01's, but both of these aren't suitable for the street. When I went to a larger brake setup, the front AP calipers came with Ferodo pads for the street which work well. Not sure what exact compound it is though.
Old Aug 18, 2005 | 10:07 AM
recon fd's Avatar
semper Fi
Thank you for your help. I was just looking to get some names of brake pad, and what people thought of them, so I could start pricing and shopping around. If anyone knows of a good deal on any of the brakes mentioned, please let me know I would need them for street. Thank you for all your help.
Old Aug 18, 2005 | 10:42 AM
Mahjik's Avatar
Mr. Links
For the street, I would recommend either the Bonez Stage I pads or the CarboTech Bobcats.
Bonez: http://www.rx7.com/store/rx7/fdbrakes.html
Bobcats: http://www.dpeweb.com/ProductsList.a...oductTypeID=14
Old Aug 18, 2005 | 03:08 PM
Sgtblue's Avatar
Urban Combat Vet
Has anyone replaced the stock rotors with a rotor the same size..... Just fishing for info about brakes. I don't want to go bigger, jsut want to chage my pads, and possibly rotors.
recon,
FWIW my car is currenly just street driven, but I'm considering attending an open track event and possibly a rally in the future. I understand that the BONEZ Stage 1 pads are rotor friendly, quiet and relatively dust free. But still able to hold up to some severe treatment. (further info is welcome though ).
I'm also considering a set of POWERSLOT rotors, at least for the front. These are OEM size and replacement is bolt-on. Currently I'm still using OEM.
Old Aug 18, 2005 | 03:33 PM
Mahjik's Avatar
Mr. Links
Originally Posted by Sgtblue
recon,
They will stand up for a little track abuse, but not too much. The track I ran them on was about a 2 mile course. I ended up fading them on the 5th lap on a semi warm day. I just backed the straight-away speeds down a bit and was fine for the rest of the day (as I really had no business going as fast as I was at that time anyway).
I ended up switching to the N-Tech Lapping Day pads for the front and using the Bonez on the rear for track days.
Old Aug 18, 2005 | 07:07 PM
Sgtblue's Avatar
Urban Combat Vet
Apologies in advance to recon.
IF I do an open track day, it'll be at MAM, which I expect your familiar with. And as a novice, I won't be pushing it very hard. Mostly (99 %) will be street. Would you still recommend the BONEZ or should I consider something else?
Old Aug 18, 2005 | 08:44 PM
rynberg's Avatar
Not being familiar with MAM, I would say that you would be fine for your first couple of track days with the Bonez pad -- as long as you are driving like you should be your first few days at the track and not in "scare the instructor mode"...
If you want to regularly do track days, you should really swap out to the Lapping Day pads like Mahjik does.
Old Aug 18, 2005 | 09:39 PM
Mahjik's Avatar
Mr. Links
At MAM, you should be ok with the Bonez as long as you take it easy on the long straight.
Old Aug 19, 2005 | 02:51 PM
WaLieN's Avatar
Call me gramps!
I use the Hawk HPS pads. Though they claim that they are low-dust pads, they do dust quite a bit (more than stock). The initial bite when cold is better than stock, but nothing to write home about.
When I replace my pads again, I will be replacing them with something else.
Old Aug 19, 2005 | 03:04 PM
alberto_mg's Avatar
I really like the EBC Greens on my FD. Good initial bite and fade free and very little dust in street driving. Haven't tried them on track yet though. Howard Coleman seems to like them also.
Old Aug 19, 2005 | 08:32 PM
ARD T2's Avatar
If price isn't a variable in this I will confidently say the Endless CC-X pad. A carbon ceramic compound that is incredibly functional but very streetable as well. This has been a unanimous conclusion by our users against all vehicle applications tested. It has also been much much friendlier to their rotors for a Carbon ceramic compound. They continually suggested that while the pads were more expensive than others, that it saved them as much or more money in rotor replacements. I thought that was kinda neat piece of info.
At a retail of $435.00 per front and rear set you can see why not everyone is using them and their benefits are not widely recognized by street/track guys in the US.
Old Aug 20, 2005 | 12:24 AM
tripleseis's Avatar
Its not even so much that the japanese brake manuf. make great pads. When you use their products and STICK to them you have a huge line of pads to choose from with totally diffrent characteristics. You know that if you go with a pad two steps softer its going to be that much gripier from cold. or if you go with a step harder you know you will have to be running that much faster to get them to work.
I see alot of people jumping brands and this makes no sence....you have no REAL compairson on the diffrence in compounds. Its like taking a stab in the dark. There are alot of people that will keep 2 or 3 diffrent sets of pads and swap them based on the track or event they are racing in. Thats how you should buy your pads.
Old Aug 21, 2005 | 10:54 AM
Carlos Iglesias's Avatar
Corn-to-Noise Converter
Veteran: Navy
Top Answer: 1
Imho
  • Street: - LOTS of choices; though I personally like HPS (not "+").
  • Track: - Have some budget: N-Tech Lapping or Comp pads
    - Rockstar budget: Performance Friction 01
Old Aug 21, 2005 | 02:50 PM
SpeedKing's Avatar
Power Trippin'
For a street car, Axxis Ultimate: http://www.axxisbrakes.com/ult.htm
Do a search on the forum - quite a few good reviews.
Old Aug 21, 2005 | 03:00 PM
FD_dave's Avatar
zoom zoom
does anybody use project mu pads? some of the mu pads are kinda affordable and i kinda want to get them
Old Aug 21, 2005 | 07:15 PM
ARD T2's Avatar
I think if you're looking to spend under a $100.00 a pad you would have a better value with a US made pad, so to speak. Hawk or Porterfield. Just depends what you want. Low Dust, Good initial response, Fade Resistance, etc....?
Please detail the functions for your vehicle and your driving style. This will allow us to recommend some pad characteristics and possible "temp ranges" you should be looking into.
Rishie
Old Aug 21, 2005 | 07:44 PM
FD_dave's Avatar
zoom zoom
Rishie
i feel like i'm hijacking this thread. forgive me
i do mostly street driving with weekly or bi-weekly canyon runs. i like to use the brakes a lot on the downhill, but i don't do any track runs or drag racing behavior. i think i mostly need pads good for everyday and occassional spirited driving with good wear and little fade coming down the hills. i'm thinking hawk hps might be pretty good for me. cheap too
i was curious about project mu's 'cuz the cheapest street pads they have can be had for around $70 a pair. being that amemiya's racing and drift cars sport project mu pads there's a bit of glamor exoticness to them
