Electrical problem
Old Aug 16, 2005 | 08:42 AM
MR_Rick's Avatar
Planning my come back
Electrical problem
My friend came to me yesterday with his FD. He had a problem with the battery and he went to get it jump to get the car going. Well the guy that went to put the cables put them backwards. Now the car is running like ****. It's popping a bunch of codes:
26 metering oil pump stepper motor
27 Metering oil pump
30 Solenoid valve - split air bypass
38 Solenoid valve - accelerated warmup system and air supply valve
39 Solenoid valve - relief 2
42 Solenoid valve - turbo precontrol
43 Solenoid valve - wastegate control
44 Solenoid valve - turbo control
45 Solenoid valve - charge control
46 Solenoid valve - charge relief control
The weird thing is that the car is set up for non-seq so most of this solenoids are not there. I swapped the ECU with a stock one (he has M2) and still the same. Any help pleae.
Old Aug 16, 2005 | 08:49 AM
NCMontegott's Avatar
This is your exit
did you check fuses and solenoids? you might of blown a few by putting the cables on incorectly
Old Aug 16, 2005 | 08:51 AM
MR_Rick's Avatar
oh yeah forgot to mention that, all fuses are good. it has to be more than that. I think all those semsors/solenoids(actually resistor in place of some of them) are all in the same harness.
Old Aug 16, 2005 | 09:39 AM
speed7's Avatar
Have the idiot who put the cables on wrong foot the bill to a local mechanic. Electrical issues are a bitch.
Old Aug 16, 2005 | 09:42 AM
MR_Rick's Avatar
well if the owner of the FD was any smarter he would have done that. But we are talking about a guy that doesn't know how to push start the car either.
Old Aug 16, 2005 | 09:48 AM
Mahjik's Avatar
Mr. Links
I suppose that he might have fried the resistors. Swap a new resistor into one of the problem areas and see if the code goes away. If it does, then that was the case.
Old Aug 16, 2005 | 09:49 AM
angelrx7HEAVEN's Avatar
V8 con
From: NYC home of thugs, killerz, and world leaders...and the fastest cars
man had a serious short in my car that took forever to sort out, i would not be surprised to see some wires meltred and contacting causing all these problem, u will actually have to see all the main harnesses for melting, contacting, or anything amiss, good luck, keep us posted
Old Aug 16, 2005 | 11:01 AM
MR_Rick's Avatar
That's what I'm going to check for
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
