location of the PVC
Old Jan 14, 2002 | 01:18 PM
minocqa's Avatar
location of the PVC
can someone tell where the PVC is located? so i can change it
thanks
Old Jan 15, 2002 | 12:12 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
@ home depot. it would be called a PCV not pvc. dont thing we have then. it would be a valve in the valve cover to the carb. we have a line with no valve from the oil neck to the carb
Old Jan 15, 2002 | 12:32 AM
REVHED's Avatar
Hunting Skylines
Mine has one. It screws into the intake manifold. I dunno, maybe the evaporative system on the Aussie models is different?
Old Jan 15, 2002 | 09:49 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
the us models have a hose on the intake but thats for vacume... runs over to the brakes
Old Jan 15, 2002 | 03:30 PM
REVHED's Avatar
Hunting Skylines
I know what the brake booster line is. The PCV screws into a bung on the manifold next to all the little vacuum nipples. The way it's setup is the vapour line from the fuel tank goes into a tee piece from which a line goes to the PCV and the other goes to the nipple on the centre plate next to the oil filler neck. The line from the filler neck usually goes to the charcoal canister but on mine it goes into one of those little K&N filters. Must work since I've never had any condensation build up in the filler neck.
ncds_fc
19
Sep 15, 2015 12:03 AM
