Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Making (programming) your own ECU?
Old Jan 13, 2002 | 10:34 PM
Barwick's Avatar
SCCA Rookie
I've had some experience with programming the 68HC11 Microcontroller (what the Haltech uses), and I'm wondering if it's possible to buy a 68HC11 board and get the "software" or something similar that Haltech uses to make the ECU.. OR if its even possible to write your own software for the ECU?
Anyone know how I might go about doing this? I think I could seriously do it, it just involves finding out exactly what I need to program into the ECU, if its as simple as calculating injector pulses, ignition timing, and O2 sensor temperatures, then I'm all over it.
Old Jan 16, 2002 | 02:05 PM
newRX7fan's Avatar
Doubtful if you can get Haltech s/w- you'd need source code also. Writing your own- you can, but it'll take 10 times as long as you think. You'll learn a lot though. One good resource if you attempt this might be www.diy-efi.org.
Old Jan 27, 2002 | 01:34 PM
Peter Ball's Avatar
I'm also looking into this as I have access to an EPROM emulator and a chip burner.
Do you know what series PROM is in the Mazda ECU and what format the code is written in ?
I also wondered if it's possible to use a flash memory chip in place of the OEM PROM so that you can change and download programmes w bit like the APEXI ECUn - is that what the Haltech chip is ?
Queppa
Nov 18, 2024 03:47 AM
Daua118
SE RX-7 Forum
Dec 5, 2021 04:15 PM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
