NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
i failed my inspection. window tint???
Old Aug 3, 2005 | 10:01 AM
MattB's Avatar
MattB
failed inspection for
exhaust leak
brakes (e-brake is sketchy)
window tinting...it got 33 (min required is 34 in MA)
exhaust i can fix easy i just need new flanges.
brakes...im gonna replace the calipers
windows....? how do i get that extra 1 point? if i just wash them real good or something do you think i could pass? is there some sort of trick i can use? i dont wanna have to get the tint taken off because that is a bitch...
any ideas are welcome.
thanks,
-Matt
Old Aug 3, 2005 | 10:03 AM
RETed's Avatar
Oh boy, this is going to get moved...
Go to another inspection station.
I think the tint meter you want to is not calibrated.
Yes, it helps to clean your glass!
Is it that dirty???
Don't use ammonia on the tint film!!!
-Ted
Old Aug 3, 2005 | 10:04 AM
MattB's Avatar
MattB
i dont think they were that dirty but i dont know what else to do...i need my tint...
Old Aug 3, 2005 | 10:20 AM
jn2k108's Avatar
hey, im from mass too. isnt the emissions a bitch here? lol
Old Aug 3, 2005 | 10:29 AM
MattB's Avatar
MattB
yeah its always fun...taking a cat off another car and having it on mine for a day just to pass...its to restrictive i tell my dad...he wants me to leave it on. NEED POWER.
SO ANY HELP WITH WINDOW TINT?
Old Aug 3, 2005 | 02:00 PM
richlrx7's Avatar
This is what I had to do in NH. I had to get a letter from my optomotrist saying that my eyes were sensitive to bright sunlight and that he recommended window tinting. I then sent that to the NHDMV along with the permit application. They sent me back a permit, only good for two years. What do they think, your eyes are going to get better in two years? I had gone to 2 inspection stations that told me the same thing, that my tint wouldn't pass, unless that is, that its factory tint. Thats the part I didn't get. If its factory, it OK???? If they're concerned with "light transmisivity" then what the hell does it matter whether its factory tint or aftermarket? Anyway, sorry if I'm ranting. So after I got the permit issued by the NHDMV, I got the car inspected. At the next annual inspection, I decided to go to another inspection station. I forgot to tell them I had the permit in the glovebox. No problem.....it passed anyway. They didn't even care about the permit. I mentioned what I had gone through and they said that as far as they were concerned, if it passes their light meter test, its fine. Mine passed by 1 percent. I know this was a bit long, but, I would try another inspection station. If that doesn't work, check with the Mass DMV to see what the regs are, and see if there is a way around it.
Old Aug 3, 2005 | 07:25 PM
spot_skater's Avatar
The Cause of Death
Slip the guy a 20 and tell him to give you the sticker.
I had to give my guy 80 for my inspection sticker.
Regarding the e-brake, what do you mean it's sketchy?
Maybe you just need to tighten the cables.
Unscrew the plastic covers surrounding the e-brake. There should be a 10mm (IIRC?) nut there, looking right up at you, tighten it a few turns. That will tighten the cables going to the rear calipers. Hopefully that's the case, and you won't need new calipers.
Good luck,
James
Old Aug 3, 2005 | 08:16 PM
edmcguirk's Avatar
I haven't seen one of these light meters but your odds have to be better on a sunny day. There's bound to be some light leakage.
Old Aug 3, 2005 | 11:24 PM
2FAST7S's Avatar
Well, this is a new one on me! They check your tints???? what the hell...i've gotten my unfair share of tickets for tints but never in a million years would i have imagined that it would be included as part of a state emissions inspection. Thats cute, I wonder what else is out there.
Go to another place or find a hook up. Good luck!
Old Aug 4, 2005 | 09:36 AM
MattB's Avatar
MattB
well i get one free retest so ill clean my windows real good and just leave them down and maybe they will forget to test it...as for the e-brake i ordered new calipers. the caliper springs werent releasing the e-brake so it just sucked...
Old Aug 5, 2005 | 08:25 PM
BlackRX7Turbo's Avatar
You're lucky that you can have tinting... in NJ, ANY aftermarket tinting on the front windows (in the case of the RX, the side windows since it's a coupe) will fail you...
trust me, I know from experience 2 inspections in a row!
(I've also been failed for not having the shift pattern for the transmission marked anywhere)
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
turbojeff
Oct 5, 2015 10:50 AM
