rotary's first problem?
Old Jan 13, 2002 | 08:18 AM
Someone told me the other day that the first problem they had with the rotary when they got it together is that they couldnt control the speed, because when it's compressing it's also firing so that it would spin up faster and faster, is that true and if so how did they solve that?
Old Jan 13, 2002 | 11:13 AM
Barwick's Avatar
SCCA Rookie
probably same as any other car, use the throttle to lower the amount of air you allow into it, and eventually it can't sustain its momentum and starts slowing down until it reaches an equilibrium (idle).
Old Jan 13, 2002 | 12:43 PM
peejay's Avatar
Old [Sch|F]ool
Re: rotary's first problem?
Sounds like that person's first problem is that they need to put the bong down!
Think about it... in a piston engine, while one cylinder is firing another is compressing, another is taking in air, etc.
A Wankel works like like a piston engine... it is still an Otto-cycle engine. The difference is that the Otto cycle's events happen all in the same spot at different times, while the Wankel's happen all at the same time but in different spots.
Old Jan 13, 2002 | 03:03 PM
allright, well was just wondering
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
1993fd3sracer1
Aug 31, 2015 07:14 PM
