Microtech Dwell on a S4 T2?
Old Aug 2, 2005 | 04:38 AM
Sindregutt's Avatar
Dwell on a S4 T2?
Got a stock S4 so what should the Dwell be? i got two maps, one with 3.0 and one with 4.5.. im using the one with 3.0 because thats the one from the previous owner.. but 4.5 is from a LT10x basmap for my car... I got a LT8
Old Aug 2, 2005 | 05:31 PM
10sec rx7's Avatar
use 3.0ms, you will burn the igniters out at 4.5ms
also did you load a map off a dongle or handset that came for a LT10s?? that could be causing your problems as there are a few different settings that the LT10 uses that the LT8 dosent
Dale
1218
Aug 10, 2016 01:54 PM
fidelity101
Megasquirt Forum
13
Apr 15, 2010 04:05 PM
1st Gen Archive
567
Nov 2, 2005 01:48 AM
