Power FC base map ???
Old Aug 2, 2005 | 02:38 AM
rx74evers's Avatar
base map ???
under the BASE map tab on the dataloggit. Higher the number the richer it gets??? or is it a combonation of fuel and ign timing? if so what does the numbers mean? I now N1 is rpm and P1 is pressure
Old Aug 2, 2005 | 07:48 AM
TailHappy's Avatar
Addicted to Track
The numbers on the base map are ms on time for the injectors. But don't forget you have to multiply those numbers by the correction map to get closer to the actual fuel that is injected. And then that is multiplied by all the other correction factors such as water and air temp....
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
