Was Running Fine, Now want Fire up
Old Jan 12, 2002 | 12:09 PM
WCBROOKS's Avatar
Hey Guys.
I was out working on my 7, started right up the way it always does. Idled for about ten minutes and then it just up and stopped. It turns over, it just doesn't want to fire up. I pulled the top plug and get the same sound repeated 3 times, so I assuming that the seals are ok.
Any ideas? From you out there. I am going to check the fuel pump to see if that is the problem.
I have never had any problem with this car in the 18 months I have owned it and just getting ready to swap in a LSD that I picked up.
Thanks for any help you guys can give.
Cole
Old Jan 12, 2002 | 01:11 PM
yayarx7's Avatar
Are you Nucking Futs?
not to be stupid or anyhting but does it have gas?
I did just what you did the other day and she was out of gas!
hope that helps
Old Jan 12, 2002 | 02:18 PM
jerij's Avatar
Ditto on the gas thing. Happened to my resto-beater twice in the past week. Shoulda learned from the first time.
However, it could be your fuel pump too.
Start w/fuel/fire and go from there.
jeryj
Old Jan 12, 2002 | 08:28 PM
WCBROOKS's Avatar
Got GAS.
Traced it down to the fuel pump wire was disconnected. Took several hours but got it running.
Thanks for the Help.
Cole
Old Jan 12, 2002 | 08:32 PM
WCBROOKS's Avatar
Jerij,
I see you are in Lexington Tn, You need to shoot down to Memphis the spring and a join use at the autocross. There is usually 6-8 Rex's there.
We have a guy that comes down from Paris in his Ford Ranger Pick-up to autocross.
See ya.
CB
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
pzr2
Aug 15, 2015 08:29 PM
zuesskroph
Aug 13, 2015 06:05 PM
Wolf_
Aug 11, 2015 04:23 PM
