Newbieee Question need help!
Old Jul 25, 2005 | 02:46 PM
88'mazda RX-7's Avatar
Sorry for such a "dumb" question but im 16, have had no experience with cars and what not, but i have to redo the sloppy shifter bushings and i dont even know how to take off the shifter ****?? any other help on this replacment would be greatly appreciated, i want to do this in the next couple of hours so hopefully someone can give me advice? Thanks
Old Jul 25, 2005 | 02:48 PM
FootWorks's Avatar
roar!
keep your right hand on under the shift **** and grip it tight. use your left hand to twist the shift **** off counter clock wise and thats it
Old Jul 25, 2005 | 02:52 PM
Thank You so much footworks, im sure ill have more questions in the future!!!
Old Jul 25, 2005 | 02:56 PM
buttsjim's Avatar
You should have a ring under the shift **** (it may be covered by the boot) that is actually a jamb nut to hold the **** on tightly. I forget what size wrench you need, but you can use an adjustable wrench to turn the ring clockwise. Doing so will allow the **** to easily turn off without damaging it.
Old Jul 25, 2005 | 03:03 PM
Ya i just went outside and fiddled around a bit thanks to both jim and footworks, now im off to go get the bushing kit!
Old Jul 25, 2005 | 03:10 PM
88rxn/a's Avatar
tom port.. AKA streetport
i did a short throw swap in ten min. its easy just watch where the bushings go!
Old Jul 25, 2005 | 04:24 PM
chasedrk1's Avatar
U forgot about Freedom
Are you saying you don't have to drop the trany when you are adjusting the shiffter? My shiffter has more play than a 2 dollor *****! it has since i bought the damn thing.
So ARE you saying it can be adjusted from inside the car?!
Old Jul 25, 2005 | 04:44 PM
well got the kit and installed it successfully! im glad it works too!: )
Old Jul 25, 2005 | 04:58 PM
chasedrk1's Avatar
So is that a yes? you did it from the cab?
Old Jul 25, 2005 | 06:54 PM
buttsjim's Avatar
You can put the bushings in from inside the car. No need to drop the transmission.
Old Jul 25, 2005 | 09:43 PM
88rxn/a's Avatar
lol. nah, inside the cab!!! remove shift ***, pop off plastic cover, 3 bolts, pull, replace bushings, and reverse the steps!
Old Jul 25, 2005 | 09:46 PM
SChema's Avatar
1988 Turbo II
how much does the average bushing kit run, and where can I find it?
Old Jul 25, 2005 | 10:08 PM
88rxn/a's Avatar
i think sometimes they go on ebay for like 30 bucks. dunno, check mazdatrix.com
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
