tiny orange plugs under UIM? -pic
Old Jul 22, 2005 | 12:53 PM
SidewaysFC's Avatar
what is this?
...i was removing the injectors and bad hoses when i saw this. i have no idea what purpose is being served.
Old Jul 22, 2005 | 12:55 PM
SidewaysFC's Avatar
also ...what is that nipple between them? ...it wasn't capped when i removed everything.
Old Jul 22, 2005 | 01:01 PM
sleeperfc's Avatar
MP T-70 = Fun
that your oilmetering injecors... looks like they have been blocked off. i hope you have been running premix.,
Old Jul 22, 2005 | 01:03 PM
sleeperfc's Avatar
MP T-70 = Fun
i also wonder what that nipple is for... im putting my car back together and i dunno where that like is supposed to go. i planned on putting a little vac cap and wire tie on it.
i did block everything off.... all of it. nothing left.
Old Jul 22, 2005 | 01:07 PM
jdmsuper7's Avatar
Looks ahead!
That nipple is supposed to help with fuel atomization with the injectors. Run a line from there up to one of the vac nipples on the UIM.
I hope you are running premix with the oil injectors capped off.
Old Jul 22, 2005 | 01:20 PM
buttsjim's Avatar
There should be 4 oil injectors. Are the other two there, and blocked off as well?
Old Jul 22, 2005 | 02:10 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
I like how it says "Car Is for Sale" at the bottom of his post and now we know that its been running without lube for god knows how long!!!!!!!
Old Jul 22, 2005 | 02:15 PM
RandomHero's Avatar
Hopeless Rotorhead
hmm, instead of blocking them off the right way, someone decided to fill the injector itself with some type of silicone sealant. big no no.
Old Jul 22, 2005 | 02:26 PM
BlaCkPlaGUE's Avatar
I live in an igloo
Yep, there are four injectors, they all have two lines each that goto them. One line connects via a banjo bolt for the oil, the other line is for the top nipple you see there in the pick. Its been debated as to what the nipple is for, and im positive that it is NOT for fuel atomization.
The middle nipple is for fuel atomization, and it will attach to a nipple on your plenum, wich has an air feed, I *believe* that is after the throttle plates? I can't remember.
Old Jul 22, 2005 | 02:31 PM
sleeperfc's Avatar
MP T-70 = Fun
so i can just put a vac cap on that middle vac nipple right? im haltech... and i blocked it off already. havent cranked yet.... i hope i can because i already did.
Old Jul 22, 2005 | 02:39 PM
SidewaysFC's Avatar
I have not missed a premix fill ever. It IS possible to know that the OMP has been removed and at the same time never know what the oil injectors look like. For not thinking before you speak Decay, you should slap yourself
Anyway ...for those of you with intelligent responses, thanks.
Can I just cap the oil injectors off with normal rubber nipple caps and remove that orange junk? - the injectors originally had a single vacuum line connected the two in the shape of a "U" (but upside down obviously). I'm not too proud of the way the previous owner put this engine back together. Though the builder is on this forum and is from Atlanta (his name has "bad" or "***" in it or something. he builds and races 4 rotors? 3 rotors? idk ...trying to figure out who it is.)
As for that middle nipple ...I think I will just hook it up into the vacuum system unless it CAN be capped.
Old Jul 22, 2005 | 02:41 PM
SidewaysFC's Avatar
I have no idea what nipples you are referring to. Can you be more specific please?
Old Jul 22, 2005 | 02:43 PM
RandomHero's Avatar
Hopeless Rotorhead
i would just remove the injectors themselves and plug them with a bolt of the right thread pitch and length.
HAILERS's Avatar
HAILERS
The one in the middle if what the fellow said, it's for the primary fuel injectors air bleeds. A vacuum hose should be going from there to one of the UPPER nipples on the rear of the intake manifold. There will be four nipples on YOUR engine. Only one is vacuum and you do NOT want this nipple in your picture to go to it. The bottom nipple is the one that pulls vacuum. DO NOT connect it there. Go for one of the top two. They lead to the front of the throttle plates, hence no vacuum.
The previous owner seems to have disconnected the oil injector lines from the injectors. So you should be mixing oil with your gas. The other two oil injectors should be on each rotor housing about three inches from the two oil injectors in your picture, but one located a bit further fwd on the engine and the other located a bit aft on the engine.
If a person had gone and decided to mix oil and gas and disable the omp, then then it seems to me all a person has to do to the oil injectors is cap off the air line to each and the oil line to each. RTV is as good as anything. I see no advantage to installing a bolt in place of the oil injectors.
There should be a oil metering pump bolted with two nuts on the bottom, right of the front cover. There should have been a metal rod attached to it, the omp, and the other end of the rod going to the throttle linkage. Got any of that?
This engine is a prime example of how a engine is not going to burn up, lock up in just a few miles without a oil metering pump or oil mixed in the gas. IT IS getting the Accelerated Wear Treatment though. Big Time.
Old Jul 22, 2005 | 03:02 PM
sleeperfc's Avatar
MP T-70 = Fun
so what is the drawback of having the air bleed blocked off? when i put my LIM on i covered the vaccume holes at that joint with the gasket and orange gasket maker. So will the air bleed still work like that?
what will be the problem with running it capped?
if i have to do it im gonna have to pull the LIM again.. no fun. i used a good amount of gasket maker so the gasket is gonna rip off i bet. yay.
Old Jul 22, 2005 | 05:04 PM
SidewaysFC's Avatar
The four nipples you are referring to are the ones that point at the firewall when the UIM is in place? Right now the top three are capped with a vacuum line going to the bottom for the ebc controller, not the actual solenoid. I should move the ebc line to the top and then add a vacuum line from that nipple between the oil injectors in my picture to the second from the top out of the four?
And I AM mixing oil with the gas and have been since I owned the car. I will locate the other two oil injectors that AREN'T in my picture and do to them as I will do to the two that ARE in my picture ...which is block them off.
I only see one line in the picture, which is directly on the top of the injectors, where that orange stuff is.
Nope. Previous owner removed the OMP ...and premixed before handing it over to me.
You mind elaborating on that? Oil injectors are blocked off and I am running premix. I don't see how you can make that assumption by the picture?
Old Jul 22, 2005 | 05:11 PM
buttsjim's Avatar
Regarding the second fitting. The orange goop is in the air line. Their should also be a banjo bolt type fitting near the base of each injector with a barb for a small clear plastic oil line running up from the OMP on the lower front part of your motor. Those fittings are probably still on your injectors.
Old Jul 22, 2005 | 05:36 PM
jdmsuper7's Avatar
Looks ahead!
I apologize for being a little vague with my first comment. Someone please correct if this isn't quite right, as I'm still learning too.
The left circled nipple is for the fuel atomization. This needs to go up to one of the upper nipples on the firewall side of the UIM. The left one is already capped, and is where the OMP injectors get their air source IIRC. The other two injectors seem to have been removed already and plugged with two bolts (arrows).
Old Jul 22, 2005 | 06:17 PM
I live in an igloo
When I said what I said, I was refering to the air feed nipples that are pluged with the red **** ontop of the oil injectors. Those goto whats called a 'vacuum spider' it just connects all four of your oil injector air feeds into one single vacuum hose, wich connects to your plenum. The right nipple on the plenum is the one in the row of 3, either on the back or the front, you can tell its the right one becuase it is larger than the other ones. I think what this air feed does is help the oil flow through the injector better, kind of like when you dump pop out of a bottle upside down. The pop will flow out alot better if there is a hole punched through the top.
bla bla bla, this doesnt' matter cause your running premix
Old Jul 22, 2005 | 06:41 PM
SidewaysFC's Avatar
Ok. Well I think I will remove the "orange goop" and just cap those oil injectors off with regular rubber vacuum caps. As for the barbs ...I don't see anything coming off the side of that injector unless it is on the other side of the injector in the picture.
If so... why not remove the other two? Also, if that is the case, then that nipple between the two injectors that are still in the engine has nothing to do with them.
Do you mean the "correct" nipple on the plenum? Or "right" as in direction? You Canadians are confusing :P
Although that does make sense, there isn't a nipple to equalize pressure for the injectors that jdmsuper7 says are bolted in the edited pic he posted. And it's soda!!!
Old Jul 22, 2005 | 09:25 PM
buttsjim's Avatar
I looked again at the picture in your first post. It appears that the previous owner removed those barbed fittings, and tried to guard against leakage by using red RTV. He would also have had to seal the oil orifice in the injectors, if that was what he did. That's kind of a hacker's way of getting rid of the metered oil system, but it'll do.
Since you're already pre-mixing, you should be ok with things just as they are. However, as someone already mentioned, it would be a lot neater job, and you'll be ensured of a better seal if you remove the 4 injectors and replace them with proper length bolts. By proper length, I mean the same length as the threaded portion of the injectors. If you do so, be sure to use copper crush washers to get a good seal.
Old Jul 22, 2005 | 11:04 PM
SidewaysFC's Avatar
anyone reason not to use that thin white thread tape on the bolts? ...wouldn't it seal better?
Old Jul 22, 2005 | 11:19 PM
Yes, I kinda figured that if the car was still running, you were pre-mixing it.....
HOWEVER..... Your the butnugget who posted a pic of OMI's talking like they were an alien growth on his car, and didn't bother to mention to anybody that you were premixing the fuel...
I thought it was funny as hell that there was a "car is for sale" sign at the bottom of the picture... I STILL do!!!!!!
So you obviously bought the car from someone who at least told you that you needed to pre-mix the fuel.... Kudos to you for buying it anyway.. most people would have been like.. WHAT?????? This aint no dirt bike!!!!!
YOU need to go find THAT guy and slap HIM for doing a half assed job of switching the car to pre-mix!!!!!!! Shoving RTV down in the holes.. Yeesh.
Old Jul 22, 2005 | 11:59 PM
HAILERS's Avatar
HAILERS
******You mind elaborating on that? Oil injectors are blocked off and I am running premix. I don't see how you can make that assumption by the picture?************
I assumed anybody mixing oil in their gas would know what a oil injector looked like. I made a bad assumption.
Old Jul 23, 2005 | 12:01 AM
HAILERS's Avatar
HAILERS
*******I only see one line in the picture, which is directly on the top of the injectors, where that orange stuff is.************
The banjo fitting on the two in the picture are missing.
