Adjust the TPS
Old Jul 22, 2005 | 11:11 AM
aceworks's Avatar
GSLSE's ROCK!!!!!
Adjust the TPS
I have the gauge that plugs in and has 2 lights (red and green). Do I want that to be adjusted so that BOTH lights are on?
Old Jul 22, 2005 | 11:28 AM
RETed's Avatar
SEARCH?!?!
-Ted
Old Jul 22, 2005 | 11:41 AM
aceworks's Avatar
GSLSE's ROCK!!!!!
http://www.racingrotary.com/tps.htm
Old Jul 22, 2005 | 12:09 PM
coldfire's Avatar
ERTW
Originally Posted by aceworks
cool, haven't seen that link before. bookmarked
and yeah, this has been covered almost as many times as "what premix ratio do i use".
- Aaron
Old Jul 22, 2005 | 12:24 PM
The Wankler's Avatar
FKITALL
Yes it has, but I have to say, I like adjusting mine at the computer with the Volt meter.
Old Jul 22, 2005 | 12:28 PM
coldfire's Avatar
ERTW
you should do both and ensure that only one light is on, otherwise the ECU may not be seeing the best signal.
also i can't strees enough how important it is to adjust when the engine is HOT. my TPS reading changes about 5% between cold and hot.
Old Jul 22, 2005 | 12:34 PM
FKITALL
Yes indeed, you are corrrect. I do have the light system as well. I started with that, and then fine tuned it with the meter.
And yes, fully warmed up.
A long *** screw dirver makes it real easy!
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
Turblown
Sep 30, 2015 05:58 PM
rotor_veux
Sep 28, 2015 09:25 PM
