miata short throw shifter writeup
Old Jul 21, 2005 | 11:09 PM
RotaryEvolution's Avatar
Sharp Claws
here it is finally, my writeup for the miata short throw shifter:
here is a link to a current online auction for the shifter i used:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
as well you will need 1 upper shifter bushing, i purchased one from the local mazda dealer for approx $7 including tax and it took 2 days to recieve.
upper bushing part number is #M508-17-481A
you can also purchase the bushing from mazdatrix:
http://mazdatrix.com/getprice.asp?partnum=17-481A-M508
you may also want to replace any ripped or torn boots after you see the condition of yours upon disassembly, you can purchase them from the dealer or from mazdatrix here:
http://mazdatrix.com/g4.htm
i prefer this style of shifter as it is a 2 piece shaft so you can choose whether you want a mild short throw or an extremely short throw. i will see if i can find a link to a supplier of these shifters off ebay so they will be available anytime not during auction periods.
to start:
1) remove the shift **** by using a crescent wrench or suitable open ended wrench and loosen the jamb nut at the base of the shift ****.
2) with a rag or something to get a good grip on the **** with, make a sharp counterclockwise twisting motion with the **** and it should break loose from the shaft. remove the **** and the jamb nut.
3) take a flat tip small screwdriver and place it under the shifter trim surround and pry it upwards to pop the locking tabs loose and remove the shifter surround.
4) remove all the boots that seal the top of the shifter housing.
5)remove the shifter housing top seal/gasket.
6)remove any remnants of the top shifter bushing and pull out the shifter shaft being careful not to drop any pieces of bushings or other materials into the housing.
7) remove the bottom shifter bushing or pieces of the steel cage that is left.
8)clean out the housing of any debris.
9)siphon any excess lubricant out of the shifter slide bore and housing, you can remove as much of the gear oil as possible and refill it so that the level of lubricant is half way up the shifter slide bore(the square piece with a bore in it).
10)now you have to remove the slip collar from the new shifter assembly and sand approx 1mm from it's diameter as the stock miata shifter is slightly too large for the FC3S shifter bore. you can do this by placing some medium grit sandpaper on a flat surface and rolling the collar while sanding it. place the collar back onto the shifter ball and try placing it into the bore, when it slips in and pulls out easily you are ready to install it.
11)once you have the shifter collar ready you can setup the pieces for assembly.
12)now place the smaller aluminum collar into the bore of the shift housing with the groove in the collar face down interlocking with the dowel in the housing:
13) now remove the steel collar from the white lower bushing that came with your short shifter and lube it up with some petroleum jelly or gear oil and place it on top of the collar you just installed:
14)take the large diameter spacer collar and remove the allen key screw, place a srop of blue locktite onto the threads and install it snug into the collar.
15)install the large diameter collar onto the housing aligning the holes with the bolt holes in the stock housing, the allen guide screw will face forward and be near the bottom of the collar bore.
16)install the shifter shaft, guide the bottom slide bushing into the shifter bore and align the keyway in front with the allen guide screw. push the shifter down into the bore so it all is aligned:
17)take the top bushing you purchased seperately and install it on top of the shifter ball in the bore so that everything is snug, do not add a spring washer to this bushing unless your shifter happens to be loose, more than likely it will be a bit tight until it breaks in(i have the washer installed in this picture, disregard unless your shifter happens to fit loosely):
18)now install the top cover gasket, if you don't have one you can substitute anaerobic sealer, gasket maker or even a small amount of silicone. install the top cover and boot assembly and tighten the bolts snug.
19)now reinstall the rubber boots for the top of the shifter housing in the reverse order you removed them.
20) install the shifter console cover.
21) now you can play with the different lengths of the shifter and see which you prefer, the super short or the stock length shifter with short throw:
the shifter may be a little tight, it will break in slightly. if you think it is too tough you can disassemble and remove the bottom bushing steel spring washer to help loosen it up. keep in mind as you drive it you will get used to how it shifts, the super short shifter is an acquired taste and it will free up as you drive it. the stock height shifter is easier to shift but the throw is also a bit more than the super short shifter but a bit less than the stock shifter.
also, you will need to pick up a shift **** insert for the **** to fit this shifter as the threads are a bit small for the stock shift ****, you can try varying suppliers for a thread fit adapter for the stock **** or fabricate your own with PVC. as you can see i just purchased a tall B+M shifter **** for my super short shifter, the adapters needed are in the kit. the stock S4 **** will not fit the larger threade base section.
if you have any questions about this install feel free to send me a PM.
if anyone happens to come accross these shifter kits on a website please let me know so it can be added to this writeup as i have no part# or a make for this kit.
yes i know i need to clean my car.
Old Jul 21, 2005 | 11:14 PM
Stanello's Avatar
backslash beanbagrace
Very good write-up. I will be doing this shortly.
Old Jul 21, 2005 | 11:17 PM
Sharp Claws
thanks
i put about 5k miles on my shifter, the allen guide screw came loose on mine so i reflected this repair in this guide by adding loctite to the screw and making sure it is nice and snug, i didn't check mine initially when assembling it so the plastic guide bushing was damaged slightly.
Old Jul 21, 2005 | 11:23 PM
ddub's Avatar
i am legendary
Copied this to the archive, there have been enough threads/questions about it that it's helpful being there for good.
Old Jul 21, 2005 | 11:26 PM
MrFuzzy's Avatar
Damn Right It's Me
Wondering how you make it a super short did you just remove the weight section that screws on to the base and put the **** on that? Also when i installed it i took the metal ring that holds the stock shifter in place and used it for this one did you do that or just loctite and bolt the ring down?
Sharp Claws
thanks.
if/when i find a source for these shifters i will let you know so you can edit the thread.
edit for MtFuzzy: yeah i knew i was forgetting something, yea the shaft is 2 piece if you decide to get one you will see what i was referring to as in the super short shifter, there is another 3-4" extension piece that makes the shifter taller or as you can see in the installation pics the fat threaded base section which can fit a shift **** also which is what i refer to as the "super short throw shifter" as seen here:
Old Jul 21, 2005 | 11:31 PM
MrFuzzy's Avatar
Damn Right It's Me
that 3"-4" section is the weight to help you shift isnt it? I got one a few weeks ago right after you did heh there pretty sweet, I was lookin at the fat threaded part but didnt know they made ***** that big thnx
Old Jul 21, 2005 | 11:34 PM
Sharp Claws
yeah, it is why i said it is an acquired taste. the weight isn't so much to help the shifter as it is pretty light actually, it is just stout to help prevent the shaft from bending. i would suggest trying both ways and see which you prefer.
the B+M **** fits, but i cannot guarantee every shift **** will fit the larger threaded base section for the shorter throw. i do know that the stock shift **** will not fit that piece though..
Old Jul 21, 2005 | 11:42 PM
MrFuzzy's Avatar
Damn Right It's Me
here is a pic of the ring i was asking about
Old Jul 21, 2005 | 11:45 PM
Sharp Claws
you will still need that boot, it is in this step:
the boots generally are in pretty bad shape so you may need a new one. slip the boot over the shifter and tighten it down then reassemble the console.
Old Jul 22, 2005 | 12:07 AM
KingCobraV9's Avatar
Rotary engine victory
why did your shift **** sudenly change? aside of that awsome how-to!
Old Jul 22, 2005 | 12:09 AM
Sharp Claws
i used the stock S4 for the longer shifter arm pic to show the length variations of the 2, the second pic is of my B+M tall shift **** i used on the base section for a shorter shifter as the stock S4 **** won't fit those larger threads.
Old Jul 22, 2005 | 12:14 AM
ah ok i got ya i thought u had the extention piece on it but had to change the **** because the threads were diffrent.
Old Jul 22, 2005 | 12:24 AM
Sharp Claws
the threads are different and why i used the different *****, you can see the fat threads in the pic i posted i a few replies above on the extension piece vs the main shaft.
Old Jul 22, 2005 | 12:49 AM
Jager's Avatar
Tear you apart
Are Miata short throwers cheaper? Better fulcrum point? Whats the benefit over a Mazdatrix?
Old Jul 22, 2005 | 01:04 AM
Sharp Claws
same fulcrum, this whole project costs about $60-70 so it is a cheaper alternative to the mazdatrix SS.
Old Jul 22, 2005 | 08:30 AM
Mordachai's Avatar
_
Thanks for doing this Karack
|M|
Old Jul 22, 2005 | 04:28 PM
Turbo7MN's Avatar
S4 is sexay!
Okay, just to clear this up: Will the stock S4 shift **** will screw directly onto the extension piece? Or do I need some kind of adapter or something?
Old Jul 22, 2005 | 05:53 PM
Sharp Claws
my guess would be no, without having a S5 shift **** lying around i can't say for sure whether it would fit without an adapter or not.
Old Jul 22, 2005 | 06:03 PM
SexInDaRex's Avatar
the S5 **** fits the extension piece. I too have this shifter thanks Karack
Old Jul 22, 2005 | 06:06 PM
Agent_D's Avatar
rawr
one thing, does this short shifter work like a Mazdatrix or mazdaspeed, i always see different numbers in shift length, 25%, 30%, 50% etc
there are a few on ebay right now, 39.95 plus 14.95 shipping
Old Jul 22, 2005 | 08:51 PM
Turbo7MN's Avatar
S4 is sexay!
I asked for S4, not S5. You said something about a "shift **** insert" and I was unsure if you were referring to the stock **** or the B+M ****. I'd really like to know because being able to use the stock S4 shift **** is a big selling point for me
Old Jul 22, 2005 | 08:52 PM
Gregs's Avatar
i advertised this in the first gen section cause series 2-4 used the same shifters so us fb guys can use this to our advantage also
-greg
Old Jul 22, 2005 | 09:22 PM
Sharp Claws
the S4 **** will not fit, the threads are too small on the new shifter, you will need to find the proper sized adapter or fabricate one.
Old Jul 22, 2005 | 10:05 PM
Turbo7MN's Avatar
S4 is sexay!
Where did you get yours? Or is it actually screwed on in that picture?
