LSD Diff - how to check?
Old Jul 21, 2005 | 11:53 AM
slvr7's Avatar
With the clutch type LSD's on S4 cars, is there a torque 'spec' to apply in diagnosing if the clutch plates are worn out?
I suspect mine is noi longer locking up, but would like to have a check procedure to verify.
If I lift one wheel and put the torque wrench on it, the clutch pack will release and the wheel will turn at 18 lb-ft.
Anybody have any links or experience with this?
Thanks,
Old Jul 29, 2005 | 03:28 PM
geargrabber's Avatar
I rolled down a mountian
you know, i was think of the same thing.
Old Jul 29, 2005 | 03:44 PM
Bob_The_Normal's Avatar
Grah, you should know better geargrabber... FSM has what you NEEEEED.
--Gary
Old Jul 29, 2005 | 04:28 PM
JMY952's Avatar
Originally Posted by I don't want to buy a shop manual for my car, is there a place where I can still find out the information from one
Shop manuals for both series can be found on-line at:
[URL
^ Taken from the FAQ.
Old Jul 29, 2005 | 04:47 PM
RoadRaceJosh's Avatar
Hobby or mental illness?
I didn't see any breakaway torque specs when I was doing my TII diff teardown last weekend, but 18 ft/lb is pretty wimpy. I have over 50 ft/lbs breakaway torque on my TII diff. Don't forget that torque applied to both wheels in the same direction forces the pressure rings apart and puts pressure on the clutches increasing the lockup. Without engine or braking torque you are only measuring the torque capacity provided by the preload of the conical springs against the clutch pack. The TII diffs have 3 springs on each side, NAs only have one, BTW.
Old Jul 30, 2005 | 05:21 AM
Okay... so... what the hell is my name doing at the end of that quote if it's taken from the FAQ?
And THAT ^ is how you do a quote btw.
--Gary
whinin
Mar 30, 2019 07:53 PM
rotor_veux
Sep 3, 2015 07:10 PM
rx7shirley
Sep 2, 2015 02:11 PM
