What turbo do you recommend for 375-420 rwhp
Old Jul 18, 2005 | 04:53 PM
PhatManBUD's Avatar
Just wondering which turbo you guys would recommend for 375 rwhp to 420 rwhp.
The supporting mods are:
3" downpipe, midpipe and catback.
Power FC
550 cc primary and 1300cc secondary
FMIC
Street ported motor
ignition system
50mm wastegate
Im looking for something with a fast spool that wouldnt run outta breathe. Something where if i i wanted to i could up the boost to around 16-17 psi and hit around 420 rwhp. But something also that i can run about 13-14 psi and be at 350+rwhp. Im very skeptical about the turbo i have now. Its the xspower one. I basically just bought it hoping it would fix my smoking problem (thought i had a blown turbo) but now that i have it, i just plan on breakin in the motor on it til i can afford a nice one. The hotside is 1.15 and the compressor side looks really small so i figure its probably not gonna supply enough air for what i want. Any suggestions?
attached are the pix of the turbo now, do you think its even capable of 350?
Attached Thumbnails What turbo do you recommend for 375-420 rwhp-dsc035423.jpg   What turbo do you recommend for 375-420 rwhp-dsc035432.jpg
Old Jul 18, 2005 | 06:49 PM
kabooski's Avatar
Laying Down Rotary Law
60-1 4" inlet
not the Hi-Fi
Old Jul 18, 2005 | 06:52 PM
FD Rey's Avatar
I brake boost
^ what he said
Old Jul 18, 2005 | 07:28 PM
AMRAAM4's Avatar
twinturboteddy ws my idol
Power FC
FMIC
Street ported motor
ignition system
50mm wastegate
you need to include "Aluminum AST tank" in teh parts list with your new turbo. You're begging for trouble with that stock piece of **** still in there.
GT40R
GT40
GT35R
R85
T04S
are all on "wait" or backorder as of a couple weeks ago when I checked around. Just a heads up.
Old Jul 18, 2005 | 08:22 PM
Zero R's Avatar
Just in time to die
35R's on backorder??? Not so sure.
Old Jul 19, 2005 | 12:48 AM
PhatManBUD's Avatar
is eliminating the ast not okay? oops, thats what i did.
so a 60-1 not hifi. could i find that on like cheapturbo.com, where do you guys recommend i look?
what size exhaust housing and compressor housing? like 1.00, or 1.15?
which would be the most cost effective turbo?
Old Jul 19, 2005 | 12:58 AM
nyt's Avatar
nyt
60-1s are great. if youre going divided manifold, go 1.00, undivided go .84 or .96
Old Jul 19, 2005 | 02:04 AM
PhatManBUD's Avatar
http://store.yahoo.com/cheapturbo/garrettto4s601.html
so this turbo and a 1.00 a/r? that would be perfect for what im lookin for? 370 rwhp on low boost and 420rwhp when i want to run a little more?
Old Jul 19, 2005 | 03:21 PM
PhatManBUD's Avatar
yes no?
Old Jul 19, 2005 | 04:14 PM
FD Rey's Avatar
I brake boost
that's a good turbo, I say yes, it will give you what you're looking for.
Old Jul 19, 2005 | 06:38 PM
nyt's Avatar
nyt
yep
Old Jul 19, 2005 | 09:27 PM
cewrx7r1's Avatar
Eye In The Sky
Replace those 1300CC secondaries and get some 1600s if you want over 400RWHP with a low duty cycle.
Also junk the useless AST as it is not needed and is just more clutter.
Old Jul 19, 2005 | 09:30 PM
PhatManBUD's Avatar
oh hmm, well i already have some 850cc injectors sitting at home, and is there anyway i can get em bored out to 1600cc? i dont relaly want to use them as primary i dontk now why
Old Jul 20, 2005 | 08:05 AM
FD Rey's Avatar
I brake boost
There's nothing wrong with running 850 primaries. A lot of us do it, and have been doing it for a long time. If fuel economy is a concern, then you should have it tuned conservatively at narrow throttle (normal city driving). Spend a little bit more money and buy a rail and a set of 1600s. Do you want to run a safe duty cycle with plenty of room for more boost in the future, or do you want to be on the boarder line running a high duty cycle with a small limit of boost? If you want 420rwhp and run it "safely" then you need bigger injectors all the way around.
Old Jul 20, 2005 | 08:39 AM
aREX4X's Avatar
I run an R85, had Steve Kan street tune it last week. The butt-dyno says it's 400whp, but I'll know for sure next Sunday.
X...
Old Jul 20, 2005 | 09:25 AM
PhatManBUD's Avatar
oh...well can i just put the 850s in the primary and keep the 1300 secondary? should that be sufficient for 420 rwhp. I dont think i plan on running anymore boost after that. Pretty much im hoping 370whp is enough to beat mostly anything. and if i had to or running a track. Id like the option to turn up the boost to hit that 420whp mark safely. And if the 7 loses then, then i guess id have to call up one of you guys to come out and whoop someone! =D haha.
Well now that i think about it. i think i will go with a fuel rail and bigger injectors in the future before i start boostin the car hard. Just to be on the safe side. Lets say i do get the 1600 cc... and you say i can run more boost. how much hp do you think i could possibly get out of the setup, max? while still being able to drive my car home after a few runs haha.
Old Jul 20, 2005 | 10:58 AM
FD Rey's Avatar
I brake boost
The key to hitting those desired 4XXrwhp number with that turbo, is all in the tuning. Tuning is very important. There's an FC here on the board that hit 520rwhp on with a PT67 kit, the same kit had come off another FC and had barely made 400rwhp. Tuning is where it counts. You can run 420rwhp safely as long as you have plenty of fuel and be tuned for it. I say with some C16 in your tank and about 20psi you can get right around there.
Old Jul 23, 2005 | 10:43 AM
bobybeach's Avatar
Masterpower T61 1.00ar divided t4
Old Jul 24, 2005 | 08:18 PM
ronbros3's Avatar
HEY on those injectors get them flowed , just to make sure they are what you think they are , when you are passing 400 whp you had better be on the mark with injector size. RON
Old Jul 24, 2005 | 08:54 PM
kabooski's Avatar
you don't need so much turbo
if your only looking to make high 300 to low 400 horsepower
Like I said
60-1 .81 or .96 turbine housing
very quick spool up
FD Rey made 370+ at 15 psi (stock motor) with a "small" 60-1 "hi-fi" which looks as small as a T04B
a true 60-1 with the bigger inlet and bigger snail makes more power
The only problem I see is GREED
once you get use to 400 HP
you'll want more down the road
Old Jul 24, 2005 | 09:04 PM
FD Rey's Avatar
I brake boost
^ you are correct sir. I'm convinced I can hit 400rwhp with about 20psi and c16 in the tank. Remember the turbo was pretty much shot when we did those pulls. I look forward on doing a pull in 4th and actually reving it past 6500 rpm.
Old Aug 18, 2005 | 11:30 AM
PhatManBUD's Avatar
More Questions
K guys. I have a street ported motor
And i think ill be going with this:
$819.00 with 1.00 a/r
now about the injectors what size should i go with?
should i get the 2 bosch 1600cc injectors with the Rx7store secondary fuel rail? totalling $330 + shipping. seems to be most cost efficient.
but what should i do about the primaries? leave the stock 550cc in there? would that be okay? or do i have to upgrade those. and if i do, does that effect my gas mileage say i go with the 850cc (if i wanted to do normal driving for the week and not boost). When people say it stumbles around 4,000 rpm. when you dont upgrade primaries is it really bad?
OR, would 1300cc secondaries and 550cc primaries be enough to fuel 420 whp at 85% duty cycle?
Old Aug 18, 2005 | 12:17 PM
Bukwild's Avatar
good choice it should be a kick *** ride when done
Old Aug 18, 2005 | 05:15 PM
AImec Racing's Avatar
so ...no time for this
that's about my range...
.84 T3/62-1 (MAster Power Turbine, Turbonetics compressor) ... 430 @19 psi (now at 23 psi) pump gas,,,,full boost @ 3000, VERY fun to drive... daily driver and great for street racing....as someone said... tunning is the key....
that 60-1 is a nice one turbo also and i think that with good tunning and c16 you may push it around 450hp ...
Old Aug 18, 2005 | 07:23 PM
bobybeach's Avatar
the xs power 60-1 is falsly advertised. its just a small v trim not a super trim 60-1 wheel. so its only gd for max 350rwhp
