negative split
Old Jul 15, 2005 | 01:08 PM
coldfire's Avatar
ERTW
negative split
ok i had negative split in my head awhile back i thought it was just silly, but then i heard of a forum member actually running it under vacuum on his FD. i won't mention his name, he can chime in if he wants.
anyways, someone want to explain to me any POSSIBLE reason you would want to run negative split, and even how the hell that works, lol.
i mean, what EMS even allows you to purposely run negative split?
- Aaron
Old Jul 15, 2005 | 01:30 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
https://www.rx7club.com/search.php?searchid=956921
Come on...you've been around long enough to search.
Oh wait....
Old Jul 15, 2005 | 01:34 PM
coldfire's Avatar
ERTW
what the hell are you talking about??
give me one thread in your search that talks about NEGATIVE split, other than the one thread on the guy who running his FD with it under vacuum.
get that god damn search pic out of my thread.
Old Jul 15, 2005 | 02:04 PM
Zero R's Avatar
Just in time to die
You never miss a chance with that button do you Mr.
Old Jul 15, 2005 | 02:10 PM
coldfire's Avatar
ERTW
lol, this is the "rotary performance" section? i feel like i'm in the freaking lounge.
come on guys, just because you don't know anything about the topic doesn't let you post that stupid picture.
Old Jul 15, 2005 | 03:45 PM
Railgun's Avatar
I won't let go
https://www.rx7club.com/showthread.p...negative+split
Post # 3. There's 1 reference. Ask him perhaps?
Maybe YOU should take the hint and not be so defensive as I don't blindly post this just for my own amusement and health.
You only asked for one...shall I go on? And you didn't specify which thread you were talking about. But since it was there....oh, I dunno. BRING IT UP INSTEAD OF MAKING A NEW THREAD?
Sean...yeah. Can't get enough.
PFC can run neg split. You can still detonate under vac, so I can't see why anyone would want to.
Old Jul 15, 2005 | 04:29 PM
coldfire's Avatar
ERTW
hey, i just take offense to seeing that search button! lol.
honestly though, it's not like i'm asking "will these tires fit on my rims".
there has been not been much discussion on this issue at all, and i would like to get a thread on it. so it's not just for MY benefit, but for others. after all, we are supposed to learn here, not just tell everyone else to figure it out on their own...
besides posting it in any of those threads would be going off topic really...
sure, there has been plenty of discussion on running ZERO split, but no one ever talks about NEGATIVE. all i ever hear is that a lot of pro tuners are running it in vacuum, i just want to understand why...
well, thanks for the info on the Power FC running neg. split. i know the Haltech E6 can't, don't know about the e11...
Old Jul 15, 2005 | 09:30 PM
rx7tt95's Avatar
Photo Diety
I'll chime in :-) The "short" version of it is the creation of a pressure wave which pushes a majority of the unburned fuel towards the leading spark creating a bigger, hotter (your EGT's will go up) better bang. Think of the way the rotary "sweeps" the air and fuel and where that air/fuel is residing when the leading plug fires. Yep, at the wrooonng end of the combustion chamber. By firing the trailing first, you're pushing the mixture to the other end before the chamber quench becomes so small it inhibits movement. And yes, I run negative split, daily driven on pump gas ONLY under vacuum.
Michel
Old Jul 16, 2005 | 12:17 AM
PDF's Avatar
PDF
Michel
Is there a noticable difference in fuel economy or off boost power?
Old Jul 16, 2005 | 05:47 PM
RandomHero's Avatar
Hopeless Rotorhead
Why is everyone on this forum so intent on shutting down threads with a massive search button. Sure this topic has been covered before, and i searched for more information on timing split, but you get a huge list of threads, maybe if you sifted through all of them you could get closer to understanding how it works. But whats wrong with having a thread all about this one topic?
I have to admit that when i first got into rotaries i was puzzled why the leading plug was on the bottom and fired first, because it would send the flamefront the opposite direction from the spinning motion of the rotor.
What your saying certainly makes sense, but when the trailing plug fires on the front rotor early, wouldnt that pre-ignite the mixture on the rear rotor?
Old Jul 16, 2005 | 06:01 PM
rx7tt95's Avatar
Photo Diety
Yes it does, partially....and that's how you get the push in the other direction. I do get excellent gas mileage during steady state cruising. I do run her fairly lean on the highway, in the 15's. The whole point of running neg split is to increase the EGT's and get INTO boost sooner than normal. I do this partially because I run lower compression rotors than the stock 93+ FD rotors. This helps eliminate any of the laggy feel provided by the low comp rotors and large ports. I haven't hooked up the prototype secondary butterfly controller yet, keeps the secondaries closed until a preset boost level, say 3psi, then slams them open. Both are designed to boost the bottom end. Currently, I have the secondary (double throttle) hooked up but it opens fully at WOT even under vacuum. Once I get the solenoid hooked up and working right, I'll be able to set it at a predetermined point.
On the search note, there's never been a thread specifically about neg split. It's buried in my CLR Motorsports engine post which is pages long. Not easy to find! So it's good we get a "negative split" thread going.
Old Jul 16, 2005 | 06:40 PM
RandomHero's Avatar
Hopeless Rotorhead
I think i see where you are going with this. You keep the neg. split to get some good exhaust velocity before spool up on a turbo car. I know the F-con v-pro has individual timing maps for leading and trailing, also the emanage ultimate is supposed to have this capability as well. Where would the benefits be (if any) for an n/a car?
Old Jul 16, 2005 | 06:58 PM
GT1-20b's Avatar
.......................PFC can run neg split. You can still detonate under vac, so I can't see why anyone would want to.
Dude,
If You detonate while in vacum, ?? ........You have OTHER MAJOR ISSUES.....
Old Jul 16, 2005 | 07:22 PM
Zero R's Avatar
Just in time to die
This is true I know nothing of rotaries or how they work. Now due to me being late to the party I have no need to go into it since Michel is here to cover for me
Michel why not run a simple pressure switch type thingy on the secondaries very cheap and see how you like it first. If in need let me know.
Old Jul 16, 2005 | 08:11 PM
coldfire's Avatar
ERTW
thanks a lot for the input Michel!
now finally this thread is getting some good tech info
Michel, what EGTs are we talking about while you are running neg split? just wonder how much hotter temps you are achieving through this.
Old Jul 16, 2005 | 10:45 PM
rx7tt95's Avatar
Photo Diety
I believe there are benefits to running neg split in vacuum too but I'm not well versed on n/a rotary engines (we're talking pro-level racing engines). It may help with torque production low in the rev range.
I haven't done too much experimentation back and forth between neg and positive split to be honest...I broke the engine in with a "normal" map and then switched over to the neg split. Ran into a few issues and lately I've been waiting for the local dyno to get up and running again so I haven't done any real back to back testing between the two. I've mostly been preoccupied with gas mileage and messing with a/f ratio. I do have to mess with cruising timing and fuel, especially in the 70-85mph range as my egt's are a bit too hot (800C) for my liking. It's not causing any cooling issues however. I'm still waiting on the new front bumper and thus am running no splash guard. That's usually a big no no but the car runs below 93C on the highway no matter what the speed. And it's friggin hot down here at the moment. I'll guestimate I'm seeing 100C hotter EGT's at steady state cruise. Acclerating, it's too hard to tell as the car gets into boost very quickly.
Sean, got your back! Anyway, I do have a simple Hobbs switch in there now which is apparently adjustable. Comes preset at 4psi. Problem is, when you "adjust" it, there's no way of knowing what you've adjusted it to. Another forum member who lives in Miami gave me a head's up on a small digital pressure switch and was even going loan me one. It's remote, with the solenoid in the engine bay and the digital switch run into the cabin. You can adjust in .2psi increments and can do so on the fly. Apparently they're only $50 or so. I'm just so busy as of late I haven't had much time for anything besides work, home and family. I'll get my act together and start getting some test data and dyno numbers.
Old Jul 17, 2005 | 08:09 PM
RandomHero's Avatar
Hopeless Rotorhead
a hobbs switch huh, maybe i should sue for using my last name in that manner.lol
I was thinking about this some more. Does your split get larger as load increases? Or is there a certain point where the difference becomes unnoticeable? Also, for n/a engines having a close split at low rpms might help torque production on ported engines to get the exhaust out quicker and get the charge air in. Of course you would be throwin quite a bit of raw fuel out the exhaust, but im in the mood for a light show.lol
Old Jul 17, 2005 | 11:45 PM
cewrx7r1's Avatar
Eye In The Sky
There is a simple way to test it, as I did this long ago.
Hook up any adjustable low pressure souce to a "T" splitter. One outlet goes to the Hobbs which will have an ohm meter across it's switch to detect when it makes contact (closes), the other outlet goes to your boost gauge.
I'll let you figure out the rest.
Old Jul 19, 2005 | 03:45 PM
rx7tt95's Avatar
Photo Diety
LOL, dunno maybe there are some royalties in there somewhere if you're related in the right way. As for the split becoming larger, it starts out large and as you approach atmosphere, it zeros out before becoming positive under boost. Chuck, I'll try your experiment.
Had a talk with Carlos about neg split so I understand a bit better. I'll paraphrase a bit as he always has to put things in layman's terms with me Carlos, you need to hold rotary seminars in your free time (big pun there!).
Negative split and EGTs.
The Higher EGT's don't come fron the advanced trailing timing, but from leaner A/F ratios.
One can run much more complete combustion cycle with negative egt's and the leaner a/f ratios are a direct result of negative split. Negative split helps maintain the highly efficient conbustion and it is capable of sustaining super lean A/F's.
Without this negative split advanced (t) ignition timing, the car would simply buck and miss, while in trailing throttle or cruse; all due to not been able to maintain a stable combustion with these leaner than normal A/F's
The fact that the A/F is near stratification, it in is self, requires extremly early ignition, so that the flame kernel can propogate with enough time to catch up the leading portion of the chamber. ... Which in it self is always and constantly runing away from the flame front.
Therefore, the earlier one lights the fire, the more mixture the flame can consume before it is extinguished by the many factors that affect a Rotary engines combustion cycle.
These factors include but not limited to a) a very HI surface to volume ratio, b) cold regions of the "cylinder" walls, or side housings that are rarely exposed to high temperatures c) very hi "Gas Transfer Velocity " that takes place only on the trailing side of the combustion chamber just at BTDC. which in it self, poseses inherent characteristics of blowing out the spark, like blowing out a candle, d) the nesesity of running super cold spark plugs, due to a very low "Water jacket to surface contact ratio.
So on and so on. !!! .......I could go on for ever on this subject, but .........
Advancing the trailing timing will actually reduced EGT.
If You care to experiment. simply retard the (t) timing say 20 degrees behind the Leading (w/ out changing You'r A/F's) and whatch what happens. (I'm not going to try!)
Guaranteed, you will see your turbine housing glow in the dark while in the middle of the day ! LOL ! Try it.
You will also see Your turbocharger come apart in no time if You continue to drive for extended periods in this condition. (Ok, Carlos, I'll try it, but only if you agree to replace my turbo!)
This DOES promote a cleaner burn of spent unburned HC's .
But we are talking performance, not emissions here.
On the other hand, a less harmfull experiment WILL prove that the high EGT is mainly fuel related:
Keep Your ignition timing maps as they are, and simply adjust the fuel maps to a more traditional tune, say just below stoch. and only in tha Vac. side of map.
Guarantee You WILL see the EGt's DROP like a bomb, and fuel economy fall off as well.
Now with that in mind, a couple of notes from me. First, I get AMAZING fuel mileage for my setup on the highway. It's almost unbelieveable. My a/f ratios on cruise are in the high 15's, low 16's. I did add a bit of fuel the other day to bring me near the low 15's and my egt's dropped by about 50+ degrees.
I won't say I get very good gas mileage in town. Part of the problem is my excessively rich idle and part of the problem is my right foot. There are days I really try to baby the car, and it's tough, and the gas mileage seems to be acceptable. I have no overheating issues with the higher egt's on the highway. I've driven the car for hours straight without issue. Part of it is due to the "total package" philosophy of the motor and cooling system setup per Carlos' experience and recommendations.
I do run a fairly large turbo, large hot side, with a poorly designed manifold. I'm hoping to switch to an A-spec manifold here shortly which I'm sure will improve things a bit. It's not as laggy off boost as say a T78 and it's fairly close to a 35R in spool time (GT4088/82 hybrid plain bearing, 88 compressor with the 82's turbine on a .94 hot side housing) but I feel like I'm giving something away due to the manifold, midpipe muffler and the GReddy Power Extreme. I have a feeling switching to a higher flowing exhaust system and better manifold will make a world of difference. BUT, the good news is that if you're cruising and nail the throttle, there is no discernable lag. Granted I'm running around .95kg at the moment but it'll go from vacuum to full boost in less than a second if you're at 3K or above. The higher egt's already have that turbine spinning so when you nail it, the car just goes. Now if I just had traction...
I run B10EGV's, no fouling as of yet. I did just switch to a higher amp alternator and my idle quality has never been better. One would never know I have the phased rotors and a very large street port.
I'm going to double post this under the CLR Motorsports engine thread I started just to have it there....
Old Jul 19, 2005 | 03:52 PM
rx7tt95's Avatar
Photo Diety
Forgot to respond to this...I'm using port phased 1988 Turbo II rotors. What that means is they're of a lower compression ratio and heavier than the 93+ rotors. The benefits of using the rotors alone are reliability, ability to run more boost on pump gas and the castings are of a much higher quality. Now each rotor has been lightened to 93+ spec, balanced, and the port phasing (scallops) were added.
Normally, as I'm sure you can imagine, the lower comp rotors would hurt the engine's response to throttle inputs off boost, hurt acceleration due to the higher weight, etc...the negative split helps to undo that and I don't notice a bit of difference between the low comp rotors vs. the high comp 93 rotors. The car is very hard to stall and pulls cleanly from just off idle and revs with abandon. I have lots of tuning left to do on her but most people would be very, very satisfied with the car's response and power as it is now.
Old Jul 19, 2005 | 04:53 PM
coldfire's Avatar
ERTW
wow, some great info your last two posts! i think it has proved this thread worthwhile
it's good to see that some of these lesser known methods of rotary performance, including running those awesome "phased" rotors, is working well for you on the street.
most people are too busy trying to see how big of a port, or how big of a turbo/how much boost, they can run. there are a lot of other small details about these cars, and i think paying attention to those is worth a lot more.
- Aaron
Old Jul 19, 2005 | 05:54 PM
rx7tt95's Avatar
Photo Diety
I completely agree with you here...as they say, god is in the details. I will admit that I have very large street ports (heck they started out as Cosmo ports to begin with!) but the engine works fine, daily driven. One of the reasons I went with CLR was their reputation, their professionalism and overall knowledge. I mean they build pro-level race engines and really take the time to do things right. The knowledge alone that I've gained in knowing Carlos for a short few months has been invaluable. I've said it before and I'll say it again, if everyone paid attention to the details like CLR did in building rotary engines, I don't think turbocharged rotaries would have nearly the reputation they do for reliability issues. Certainly CLR isn't the only company out there but they're good. It also helps when you have an owner that takes things slowly. I'd like to be a bit further along in tuning and if I had more time to devote to it I would be. As is, I'm keeping things on the low until I can do them right. Carlos doesn't even think the engine will "come alive" until 15psi going by the internals It's fast enough now at .9kg to easily trounce a Z06 or any rice that comes my way. I'm not even in the engine's (or the turbo's) sweet spot yet. At 20psi, and assuming I can actually get traction, she'll be a complete beast. And reliable.
- Aaron
Old Jul 19, 2005 | 06:16 PM
Godzilla-T78's Avatar
^ Mich's car is a beast, he got his car tuned at the last tuning session last spring when we brought down steve kan. I actually went off alot of his inspiration when building my new motor. If you ever have questions hes full of some great info.
Old Jul 19, 2005 | 06:17 PM
btw, i am running a good amount of negative split on my car, runs awsome both street/vacuum driving as well as in boost.
Old Jul 19, 2005 | 06:49 PM
rx7tt95's Avatar
Photo Diety
That was the old motor...it's nothing compared to what I have now Same Cosmo block (new rear plate) but new housings, lapped plates, pretty much everything you can do. My receipt is around four pages long!
You aren't running neg split in boost are you? That's a big no no.
Michel
