i have a safcII and am doing a 302 conversion help
Old Jul 13, 2005 | 07:52 PM
ericiscool's Avatar
im selling the safcII out of my car i didnt put it in and dont know how its installed
so the question is.......
if i take it out will i be disconecting vital wires for the swap or is it just "taped into" the original sorce instead of sploced into the wires??
o and its a 302 carberated
J-Rat's Avatar
Alcohol Fueled!
If its a 302 carby, you dont need those wires anyways.
Old Jul 13, 2005 | 07:58 PM
ericiscool's Avatar
i dont know what all it controlls because i use some existing wires
Old Jul 13, 2005 | 08:08 PM
Syonyk's Avatar
The only wire that was cut was the airflow meter.
You won't need it.
-=Russ=-
Old Jul 14, 2005 | 04:35 AM
stilettoman's Avatar
No, it is not stock!
Wires you Need
A 2nd gen car will need most of the same wires as 1st gen. On my 1984 GSL / 302 conversion, the main wire bundle to the engine had 17 wires, I used 6 of them. You need the connections to the temp sensor, oil pressure sensor and 3 wires to the alternator, a 2-wire plug and the small bolt -on power wire. I also used the separate temp sensor and power wires for the choke solenoid , which you don't have on the injected car. You will also need the distributor connections.
If you go to Granny's web site, there are detailed instructions for the wiring hookups - I found it helpful.
Old Jul 14, 2005 | 03:16 PM
ericiscool's Avatar
yeah i found all the wires already i was just wondering if i would disconect any when i took out the safc
thanks
Coochas
44
Nov 5, 2019 11:08 PM
