I LUV ME SOME NONSEQ, but...
Old Jan 9, 2002 | 10:06 PM
edpaek's Avatar
I just did the poor man's mod... and damn, it's nice... I like the smoothness of it, but...problem
I did everything I was suppose to do for the mod, and. I'm only getting 6lbs of boost. And, I could swear I hear a leak as soon as I hit 6, no doubt. How was I suppose to tee the charge relief and blow off valve? I'm not sure I did it right, either that or one of them is failing. Also, do I gave to tee these two together?
Old Jan 10, 2002 | 05:52 AM
edpaek's Avatar
Old Jan 10, 2002 | 06:49 AM
puma's Avatar
canadian monster
you might have a leak somewhere else to, check the piping. They should be tee and go on one of the niple on the upper manifold, simple as that. check if you have plugged everything.
did you remove the boost pill?
puma
Old Jan 10, 2002 | 10:07 AM
edpaek's Avatar
Question
WTF? I need to remove the pill? I'm talking about the poor man's mod, not the full non-sequential mod...
Old Jan 10, 2002 | 10:09 AM
puma's Avatar
canadian monster
no you don't need to remove it but if you did you won't get more than 7 psi
Old Jan 10, 2002 | 03:16 PM
alaskan7's Avatar
Describe the lines going into and out of the wastegate controller
Old Jan 10, 2002 | 03:51 PM
edpaek's Avatar
I didn't touch those, cause every instruction I ran across said to leave them alone...
alexdimen
20
Oct 23, 2015 01:50 PM
Jedon
43
Jan 26, 2003 12:53 AM
LilFatCrazyWop
118
Jun 25, 2002 01:50 PM
Ulator
37
Jun 7, 2002 10:41 PM
