Clarion CD DECK!
Old Jan 9, 2002 | 09:54 PM
Question Clarion CD DECK!
I got the 715 pro audio deck and it worked great for a minute or two. I had verything hooked up and then cab lights and cd player turned off, Can't get them back on, have any ideas?
Old Jan 9, 2002 | 11:38 PM
Icemark's Avatar
Define cab light.
Dome light?
dash lights?
If it is dome lights you blew your constant / dome fuse in the fuse panel. Make sure you are not drawing too much current for the radio. what is the fuse ratings on the radio?
If it is dash lights you hooked up your radio to the lumination circuit and may have either blown out a fuse, or the dimmer depending on what wire you hooked onto.
Old Jan 10, 2002 | 01:11 AM
it's dome lights, door lights and hatch lights!! It was to dark to try and fix it tonight but what I could make out looked like the fuses were ok
Old Jan 11, 2002 | 01:04 PM
Newbie
Makre sure you get a fuse tester or a voltimeter to test the fuses. Set the voltimeter to continuity and touch both the pos and the neg to both sides of the fuse..... if the voltimeter beeps, its a good fuse.
7upra
Mar 25, 2018 11:32 AM
