low compression
Old Jul 7, 2005 | 10:24 AM
Kaygan's Avatar
Kaygan
low compression
Hey,
I am getting low compression on my engine for some reason. What is that transmission fluid trick that fixes the apex seals?
Old Jul 7, 2005 | 10:25 AM
jays83gsl's Avatar
1983 GSL, 1987 323 "GX"
How low of compression are we talking about here?
Old Jul 7, 2005 | 10:42 AM
Kentetsu's Avatar
....and use MMO rather than ATF.
Old Jul 7, 2005 | 10:45 AM
jays83gsl's Avatar
Oh, snap, here's someone that actually KNOWS **** to put me in my place
Old Jul 7, 2005 | 12:45 PM
Kaygan's Avatar
Kaygan
I am not sure, I didn't test it myself. I just know you can restore engine compression by putting transmission fluid "somewhere" I don't know, but I have a 85 rx7 12a and I love it, I don't want to have to replace the engine when it is still able to drive around.
Old Jul 7, 2005 | 12:48 PM
jays83gsl's Avatar
Well, if the compression is TOO low, it's not even worth doing the MMO trick.
Old Jul 7, 2005 | 02:14 PM
Rogue_Wulff's Avatar
Too old to act my age
The "MMO" or "ATF" trick is for helping engines with low compression due to the apex seals sticking from carbon buildup.
A good write-up about this can be found in the FAQ located at the top of this section, under the name "1st gen FAQ".
Much easier to have you look for that, rather than spend a long time re-typing the directions.
Old Jul 7, 2005 | 03:59 PM
Kentetsu's Avatar
Once you get her running with the MMO (instead of ATF) you might want to try the following, it did wonders for my engine (I think I had a stuck apex seal)...
When you are down to about 1/8 of a tank of gas, dump in a full can of SeaFoam. Don't add more gas right a way, drive her hard for a while first. This will be a very strong concentration and helps free things up. When I did this, after driving it for a few miles I suddenly got a HUGE surge of power and it has stayed with me ever since. Might be worth a shot...
Old Jul 7, 2005 | 04:04 PM
Killer Bee Fan's Avatar
No Pistons
Question
Sorry for this stupid question but what is the meaning for: MMO ???
Old Jul 7, 2005 | 04:21 PM
MMO = Marvel Mystery Oil
Old Jul 7, 2005 | 04:49 PM
No Pistons
Thanks for answering the question. Where can I get it because I live in Guatemala Central America.
Old Jul 7, 2005 | 04:56 PM
This stuff is usually available at most auto parts stores. I don't know if it would be available in guatemala, though. ATF (auto tranny fluid) is an acceptable substitute if MMO cannot be obtained.
MMO is a light oil, with exceptional cleaning and lubricating qualities. Almost looks and smells like ATF and carb cleaner mixed together. Generally in a red and black can/bottle.
Old Jul 7, 2005 | 06:14 PM
Kentetsu's Avatar
Actually, you could probably use any type of compatible oil for this purpose, even motor oil. Just be sure that you don't use more than is needed.
Also, you will probably foul your plugs when doing this, so pick up an extra set...
Old Jul 7, 2005 | 08:19 PM
ArmySoldier's Avatar
your auto parts store SHOULD be able to order it otherwise goto: http://www.seafoamsales.com/motorTuneUp.htm and click on contact or email : customerservice@seafoamsales.com directly. Good luck (I just went ahead and bought a new engine though I still use sea foam alot)
For MMO = http://www.turtlewax.com/ you can place an order there. also customer service email is: : customerservices@turtlewax.ltd.uk
Last edited by ArmySoldier; Jul 7, 2005 at 08:23 PM. Reason: adding additional info
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
