Sponsored by: CARiD
walboro pump - bleeding off fuel?
Old Jul 7, 2005 | 12:13 AM
Chris Ng's Avatar
I'm with stupid -----^
Just curious.. The stock FC/FD fuelpumps have little checkvalves at the outlets to prevent fuel from leaking back through the fuelpump once the pump is shut off..
according to my fuel pressure gauge, my fuel system holds no pressure at all once the fuel pump is shut off.. It drops right to 0 ...
Can some of you with walboro fuel pumps installed confirm wether your system holds fuel pressure or not after the car is turned off?
My current setup includes a walboro fuel pump, malpassi FPR, stock fuel rails, no PD...
Thanks,
Chris
Old Jul 7, 2005 | 01:13 AM
RoadRaceJosh's Avatar
Hobby or mental illness?
Hey, look on the bright side, you won't flood the engine after shutdown!
Old Jul 7, 2005 | 02:26 AM
RETed's Avatar
That is correct.
The Walbros don't have internal check valves.
-Ted
Old Jul 7, 2005 | 05:52 PM
Chris Ng's Avatar
Originally Posted by RETed
That is correct.
-Ted
Thanks Teddo ... I guess I should have checked before it was installed.. too lazy to go pull it out again
Old Jul 8, 2005 | 12:56 PM
Jeff20B's Avatar
Lapping = Fapping
That's nice to know. Thanks.
Old Jul 8, 2005 | 05:36 PM
ronbros3's Avatar
most race pumps dont hold residiual pressure after shut down. on restart you have to watch your fuel pressure come back up before cranking, sometimes annoying. RON
Old Jul 8, 2005 | 09:22 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
Not True, Walbros do have check valves on the outlet..... Mine holds pressure for days after shut down with twin walbros.Its kinda like a schraeder style valve just like comp tester..Not only that, if you twinned them like I have with them staged, and used no external checkvalves it would never build pressure while the second pump was off..max
Ps: Toss the Malpassi...
cristoDathird
28
May 30, 2019 08:47 PM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
