What to look for buying a 91 Rx7.
Old Jul 5, 2005 | 09:38 PM
rx7ofdoom's Avatar
Lightbulb What to look for buying a 91 Rx7.
Hey Im currently looking at buying a 91 rx7 with around 80k miles. I've almost bought a few in the past but ended up getting a vw gti . Well i read up on the problems on these car a while back but was wondering if anyone or a few of you could give me a quick heads up on what to look for? and what problems are no biggies and what problems i want to stay away from?
Thanks in Advancea and i hope to get rid of my VW and get a Mazda within the week .
Old Jul 5, 2005 | 09:48 PM
Snrub's Avatar
Here are a couple of links:
http://www.aaroncake.net/RX-7/buy1.htm
http://www.fc3spro.com/TECH/h2b.html
Old Jul 5, 2005 | 09:59 PM
rx7ofdoom's Avatar
cool thanks! looking at em now
Old Jul 5, 2005 | 10:35 PM
rx7ofdoom's Avatar
wow that was quite read. ill probably print it out and scare the crap outta this guy when checking all of that .
Old Jul 5, 2005 | 11:06 PM
Turbo 3's Avatar
Safety Guy
are you looking at a turbo or a non-turbo?
Old Jul 5, 2005 | 11:28 PM
rx7ofdoom's Avatar
non turbo.
Old Jul 6, 2005 | 03:42 PM
Turbo 3's Avatar
Safety Guy
Check compression; it should be at least 70 psi or more on all faces of each rotor, 90+ is prefereable.
Look at the oil fill neck; it should look like oil. If it looks milky or slimy than run away. This is a sign of a coolant leak into the combustion chamber.
Other than that it's pretty much like any 15 yr old car...check to make sure it is in good mechanical shape like normal (brakes, transmission, etc).
jdayau
Nov 29, 2019 12:11 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
