'84 SE ignition/electric wiring help?
Old Jul 2, 2005 | 10:39 PM
cpt_gloval's Avatar
KARATE EXPLOSION
so i'm working on hooking up the driver's side wiring harness. i have questions on a couple of items. it used to have power steering and ac. it doesn't anymore.
http://cptgloval.shackspace.com/cars.../greenwire.jpg -- not sure where this goes.
http://cptgloval.shackspace.com/cars/wiring/split.jpg -- what is the loop on the left and the camera battery-sized thing on the right?
thanks for any help.
Old Jul 2, 2005 | 10:44 PM
vipernicus42's Avatar
Rotoholic Moderookie
The green thing went to the "hot Start Assist" motor. If you don't have one, you don't need to worry about it. I removed mine because it was broken and have not had any problems. You just need to crack the throttle a bit when it starts when its hot. No more than I usualy do, so it's all cool.
On the second picture, the little loop attaches to the fusible link box from the positive cable IIRC. The little battery-shaped thingy I usually see on top of the engine. I *think* I remember someone saying something about it being there to clean up the signal to the tach, but mine's gone and again I've never noticed the difference.
Definitely hook that positive thing back to the fusibles if I'm right on that one. Your car will have one hell of a time running without it.
Jon
Old Jul 2, 2005 | 10:47 PM
cpt_gloval's Avatar
KARATE EXPLOSION
as far as i can tell, that loop thing doesn't reach the fusible links from where the cable ends up around the dizzy and alt (that big plug is for one of the ignitors iirc).
Old Jul 2, 2005 | 10:56 PM
gsl-se addict's Avatar
Super Moderator
The middle plugs are for the ignitors. The battery looking thing is the condensor. It goes on the side of the distributor. The large wire on the left appears to be the alt output wire. On the GSL-SE, the alt output connects to a block on the RE-EGI plenum. From there, that wire (also bolted to the block), eventually goes to the fusible links and battery. The wire should be white with a red stripe.
Old Jul 2, 2005 | 11:00 PM
cpt_gloval's Avatar
KARATE EXPLOSION
there is another condenser looking thing that comes out of the loom near the brake master cyl. where does that one go?
i'd have pics to be more helpful, but somethign is wrong with my camera's memory card.
Old Jul 2, 2005 | 11:01 PM
cpt_gloval's Avatar
KARATE EXPLOSION
i don't suppose i could bother one of you gentlemen to snap a couple pictures for my reference? that would helo me a lot.
Old Jul 2, 2005 | 11:03 PM
Super Moderator
That one bolts to the top of the engine (on an inspection plate I believe). It eventually connects to the oil pressure gauge. I am not sure of its function, really. The wire is broken on mine and the oil pressure gauge works just fine.
Old Jul 2, 2005 | 11:09 PM
TurboSE's Avatar
isnt there 2 condensors? capacitors! for each coil?
Old Jul 2, 2005 | 11:19 PM
Super Moderator
Nope. Just the one. The power is shared to the two coils (BY wire). The condensor connects to the coil +.
Old Jul 2, 2005 | 11:28 PM
Ah, so I was *partly* right.
I was thinking of the condensor on top of the engine, the one that comes out "near the master cyl" as you said.
I think that GSL-SE addict had it spot-on about pic #2. I just wasn't sure where in the engine bay it was going.
I'm absolutely sure about the hot start though
Jon
Old Jul 6, 2005 | 06:55 PM
85rx7jule's Avatar
how can i rtell if my car is a 84 or 85 rx7 ? it looks just like the one shown by vipernicus_42.
I have powerr windows and the biiook only shows that schematic for 1984 year but my registr says 1985 . it has a 12A motor but sopme of the wire are 3 color in the harness I don't see any wires in the scematics of any year with three colors it's usually 1 color then stripe then a brown dot all on the same wire? any answers?
thanks
JR in CAL
Old Jul 6, 2005 | 08:14 PM
cpt_gloval's Avatar
KARATE EXPLOSION
i'm under the impression that there are very few if any differences between 84 and 85
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
