offset question. would this fit on a FD?
Old Jun 30, 2005 | 06:23 PM
RE Suzuki's Avatar
I speak Japanglish
18x8 Front
225/40-18 tires
Offset +50mm
18x9.5 Rear
255/35-18 tires
Offset +55mm
would it fit?
Old Jun 30, 2005 | 07:34 PM
afterburn27's Avatar
Lets Go Hokies!
The fronts should fit fine, and according to jimlab's wheel/tire size calculator you will only have .09" of clearance on the rear inside. I'd wait for the experts to chime in, but that's cutting it too close IMO.
Old Jun 30, 2005 | 07:40 PM
rynberg's Avatar
Fronts are fine, rears are a little high offset (never thought I'd say that for an FD!). You'll probably clear the trailing arms but it will be close. You could run a 1/4-inch spacer (6mm) at the rears, that would work great.
Old Jun 30, 2005 | 08:07 PM
RE Suzuki's Avatar
I speak Japanglish
Thankx!!
Old Jun 30, 2005 | 08:41 PM
ARD T2's Avatar
Sounds like used wheels from an S2K or IS300. Since we have run 10 +52 on FD in rear before with the M2 Trailing links, I think that they can work but might look a bit sunken in on the rear fender.
So:
1. Get the trailing links, FD guys can refer you to Rotary Extreme or someone who now makes them.
2. 9.5 +55 should work in theory. We've done 10.0" +52 offset with 285/30/18. the 9.5 " +55 has less backspacing so it should work fine.
Rishie
BLK 93
11
Sep 9, 2015 10:56 AM
