injector question
Old Jan 8, 2002 | 01:51 AM
fc3s94509's Avatar
injector question
i bought a jdm rx7 turbo motor and i noticed that the injectors are like red in color, yet the ones in my car were like a tan color. i though the motor i picked up could be a 91 but it has a manuel omp. are the red injectors high impedence and the tan is low impedence?
Old Jan 8, 2002 | 01:56 AM
cymfc3s's Avatar
I Raise Chickens
If it has an mechanical OMP, its not a 91 unless someone swapped the front cover and water pump housing. The color is not an indicator of impedence.
Old Jan 8, 2002 | 02:19 AM
fLyiNgOuFeR's Avatar
i have a motor w/ the red injectors and my motor is an '88 t2. the red injectors are high impeadence and the tan ones should be low.
Old Jan 8, 2002 | 03:47 PM
fc3s94509's Avatar
how can i tell if my ecu is hi impedence or low impedence ecu? also whats up flyingoufer this is santos from the other side of the bay
. your lights are sick as hell. when i get my motor and turbo in i will come by.
Old Jan 8, 2002 | 05:15 PM
RETed's Avatar
Purple tops turn brown/tan with heat and age.&nbsp These are low-impedence.&nbsp Check the mount tab on the plug - it should be off to the side.
Red tops turn pink with heat and age.&nbsp These are high-impedence.&nbsp Mount tabs are in the center.
-Ted
Old Jan 8, 2002 | 08:18 PM
Bambam7's Avatar
I came, I saw, I boosted.
I believe all the ECU's are, as you put it- "high impedence"
The 86 to early 87 (not later 87's) utilize a resistor pack under the air filter to up the resistance of the injectors. The 88+ don't need the resistor pack, as they use high impedence injectors.
Old Jan 8, 2002 | 08:24 PM
RETed's Avatar
Oops, didn't quite read the post correctly...
Bambam7 is right...the ECU expects a high-impedence load on each of it's fuel injector channels, regardless of the fuel injector type.
-Ted
Old Jan 12, 2002 | 01:25 PM
fc3s94509's Avatar
does anybody know if i can remove the resistor pack that bambam7 is talking about to run high impedence injectors also can you discribe better where to find the resister pack and what it looks like.
thanks .............
Old Jan 12, 2002 | 02:06 PM
HAILERS's Avatar
HAILERS
This post https://www.rx7club.com/forum/showth...threadid=16225 and the answer by Keith. EDIT; I seem to be having trouble today. Yes. Go to the resistor pack which is mounted to the structure about a half foot below the air fuel meter/air filter. You should see a silver assy there with a large elect plug. It would be a simple matter of disconnecting the plug. Then finding the power wire. Splice four wires off the power wire and connect them to the four wires that are going to the injectors. If you need colors I'll look them up, but what it amount to is just jumpering around the resistor pack with the 12v power source. EDIT; Just to clarify this messy post, once you disconnect the plug from the resistor pack, you don't do anything with the resistor pack or its plug. It can sit there and rot. Just jumper the wires on the plug that went to the resistor pack.
Skeese
65
Mar 28, 2017 03:30 PM
morataya
Microtech
Aug 16, 2015 09:39 AM
