Tracking Down the Problem
Old Jun 23, 2005 | 09:13 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Cool Tracking Down the Problem
Ok i have been Tracking down a Problem with a Check Engine light, Well i have done everthing and still cant find anything wrong. I have changed the CAS, the Connectors and wires going to the ECU, Then i have changed the ECU with a few that i have had.
Background - 93 R1 Stock Twin Seq 112,000 (Been sitting a few months (3-5))
The start of this Problem and story started here
https://www.rx7club.com/forum/showthread.php?t=427175
I fixed the coil problem
After i changed the wires
You like how clean these look!!
So the is nothing wrong with the CAS system but i still have the Check Engine Code.
Ok well i dont no why the code is still there but, i tryed to crank the engine and it started but was really Rough, and poping alot, would not idle eather. So i am thinking it is a fuel problem now, The fuel pump was bad when i got the car, so i changed it, but didnt drain the gas that was in the car. ( )
So i am thinking that maybe i have all that bad gas tar on the fuel injector screens. Beacaue i am not getting hardly any fuel in the enigne, It is Hard to start and will no rev right, ( I am trying to get a video on this, so i can explain it better )
This is proable the last thing i try before i take the car to maz max and tell them to fix it, i have been working on rx7's sence i was 15 (22 now) and have only have FB's and FC's so this is my frist FD and it is really pissing me off.
I have also installed a push button start because the ignition switch messed up
So if you guys have any other opitions on what can be wrong
The compression on the motor is FR 6.2 6.7 6.5 RR 6.5 6.6 6.3 ( Cold Engine Auto Starter) So the engine turn slower than a 5 speed
Old Jun 23, 2005 | 09:43 PM
Kas's Avatar
Kas
I have the same problem with my FD also,let me know the solution if you find it.
Old Jun 24, 2005 | 03:44 AM
Rx7_Nut13B's Avatar
bump^
Old Jun 24, 2005 | 07:43 AM
Rx7_Nut13B's Avatar
Come on, Anyone??
Old Jun 24, 2005 | 10:44 PM
Rx7_Nut13B's Avatar
Bump
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
The1Sun
Sep 15, 2015 04:45 PM
