engine swaps series 4 to series 5
Old Jan 7, 2002 | 02:42 PM
hIGGI's Avatar
do i have to change harness/ECU when swapping Series 5 turbo motor into Series 4 turbo car ?
i tough that i have to change harness/ecu only for NA to turbo swap.....
Old Jan 7, 2002 | 03:19 PM
hIGGI's Avatar
+ for those questions
what would u do with blown series 5 turbo motor (probably just water seal or something not bad for rotors/housings and good series 4 turbo motor ?
Old Jan 8, 2002 | 12:54 AM
FC3sRacingSD's Avatar
Swap
Nope. There is a couple of things you have to do. You need to use 2 cycle oil premix in the gas.....1oz per gallon and if you have the early 87-88 model.....you need to use your injectors off the series 4 motor. Low impedance. If you have the later 88... June of 88 and on...then you dont have to worry about swapping injectors. I have been running this combo for 2 years and had no problems at all. It runs cleaner also because of the 2 cycle oil. It burns cleaner than conventional oil.
Old Jan 8, 2002 | 01:09 AM
hIGGI's Avatar
what about using series 4 block and series 5 injectors, fuel rails, all intakes, turbo and stuff ?
what about oil metering pump ?
Old Jan 8, 2002 | 10:16 AM
the krza's Avatar
if you run premix like FC3sRacing said, you will have no need for the OMP.
....im not sure if you absolutely HAVE to do this, but you may as well
elfking
Aug 19, 2015 09:48 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
