NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Need help finishing my engine install in RI, everythings almost done!!help!!
Old Jun 17, 2005 | 11:36 AM
wthdidusay82's Avatar
Rotary Power
I already have the engine in and attached to the tranny, this is my first time installing an engine in any car so im not too sure about some things, mainly the wiring and the oil lines, vacuum lines, fuel lines etc
the only things left to install are the wiring , intake manifold/intake, fuel rails, oil lines/omp etc, vacuum hoses, fuel hoses, coolant hoses and a wire that broke on the oil pan needs to be taken off and swapped with my other one( the one that has a big nut/stud with a wire on it)
i dont know much about timing so help with that would be good
there really isnt much else i need to do that i cant do myself, i do want to check the coils for power to make sure they are working before i start cranking the car to start it up... becausae i had to replace the wiring harnesses/ecu because i was told it had no spark/ no power to the coils before , everything has been swapped aside from the harness on the tranny to the front engine bay fusebox
even if someone has an rx7 to go by for reference would be good, my car is a s4 na
help would would be very greatly appreciated and youll have a new rx7 owner to be friends with now that i will finally have my car running
need help asap
Old Jun 18, 2005 | 07:06 AM
Rotary Power
come on cant someone help me out ? if money is what you need i guess i can give some money to someone that helps but really its not that much work left to do at all, ive already put at least 30-40 hours of work into my car and it isnt running yet and its so close
Old Jun 19, 2005 | 01:36 PM
Rotary Power
come on no one is going to help me ? i have to do the work myself and i really dont have much experience...help would be greatly appreciated
Old Jun 22, 2005 | 08:13 PM
Rotary Power
anyone ? please id love to have some help .. ill offer 50 bux to anyone who will com and help me
Old Jun 23, 2005 | 04:35 AM
MichaelFregoe's Avatar
Where are you located exactly? PM me. I have installed many engines
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
