Oil in the Throttle Body?
Old Jan 6, 2002 | 10:28 PM
SpeedRacer's Avatar
Formula Mazda Driver
Alright while messing around with my car today, I noticed oil in the Throttle body. I have a 90 GTU, so I have no clue how oil could get into the TB. I am thinking maybe somehow the Purge control valve is malfunction? Any ideas?
Old Jan 7, 2002 | 11:17 AM
SpeedRacer's Avatar
Anybody have any ideas?
Old Jan 7, 2002 | 11:30 AM
RETed's Avatar
I know how the turbo FC's run it's purge valve back into the TID fitting, but the NA's should have a similar set-up.&nbsp Yep, you pretty much hit it on the nose...
-Ted
Old Jan 7, 2002 | 11:33 AM
go_speed_go's Avatar
Any chance you got a little to excited the last time you oiled your K&N?
Old Jan 7, 2002 | 11:41 AM
SpeedRacer's Avatar
Hehe...actually, yes. I didn't even think of that. But still I'm pretty sure this is castrol GTX oil, it smells different than the K&N oil.
so as I understand the PCV, it uses vaccuum off the throttle body to pull vapors from the oil crankcase or whatever, and recirculates them into the intake stream to get rid of them. So how could oil get sucked up into into the TB, unless the oil level was too high or something, or WAY to much vaccum was being applied to the PCV or something? How could I go about troubleshooting this? This is probably why my car is using oil, and blowing blue smoke on startup.
CaptainKRM
14
Aug 26, 2015 09:52 PM
