Microtech wiring help
Old Jun 14, 2005 | 03:34 PM
sidewaysII's Avatar
wiring help
I just bought a microtech lt8s and started hooking it up but i am having some trouble with what to get rid of wiring wise on the stock harness if some could just tell me which color wires to keep off the stock harness and what connectors that would be great
sorry if this question was already answered on here before I tried searching but could not find what i needed thanks
Old Jun 14, 2005 | 03:47 PM
Broken09's Avatar
I am becoming...
What year is your car?
Old Jun 18, 2005 | 02:07 PM
sidewaysII's Avatar
s4 harness with s5 motor
Old Jun 20, 2005 | 02:50 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
i'd lose the harness completely.
use your injector connectors (unless you got new ones), coolant temp, and air temp connectors.
you can wire it up to the cas at the sensor, but i prefer to wire that part into the factory harness (front harness). that's the one connector you pulled from the stock ecu that you don't remove with the engine harness.
other than that, it's pretty straight forward.
Old Jun 20, 2005 | 11:15 PM
BOOSTED Vert
yea, or you can do what I did and remove the clip from the stock harness and connect it using the MT leads. the rest you can throw away. The oil press, coolant temp, and rpm are all on the body harness.
Old Jun 20, 2005 | 11:46 PM
sidewaysII's Avatar
when i pulled the stock engine harness it had 2 connectors that go to the ecu and these 2 orange looking ones (one of them has the wiper motor wires going to it) am i just going to cut the rest of the wires off of the wiper motor connector and do I need any of the other wires in the other orange connector?
p.s. where would be a good place to plug the vac hose from the MT , any where on the intake manifold?
thanks for the help so far
Old Jun 21, 2005 | 12:03 AM
just slit the insulation from the harness. the wiper motor harness will pull right out, but you might have to pull a pin or two, then reconnect them--they're tangled sometimes.
either way, no biggie. the wiper harness is in its own little world--even though it's loomed with the engine harness.
Old Jun 21, 2005 | 12:25 AM
BOOSTED Vert
also the exciter wires are on that plug. The two wire from the back of the alt.
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
