Haltech TPS reads"fault" at rest
Old Jun 13, 2005 | 06:44 PM
Carl Byck's Avatar
Mad Man
Like it says, is this normal? At rest the on screen info alternates between fault, and 0%, same thing when I put the pedal to the floor, 100% then "fault". I just never noticed before. It is at the extrems of travel though. Ther is also a tiny bit of play, as the plastic has worn a little where the shaft goes into it, less than 5* I'd say. Can I (should I) just epoxy it in the "0" position at rest? thanks, Carl
Old Jun 13, 2005 | 06:48 PM
tims's Avatar
I have the same problem at the idle position. doesn't seem to be a problem
Old Jun 13, 2005 | 07:11 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
This probably means that your TPS is probably going beyond the range of the calibration. Have you properly calibrated it? also, if you turn the idle air screw on the throttle body, this will merit recalibration of the TPS again. Also, please note that everytime you recalibrate the TPS, the throttle pump settings will be affected.
Old Jun 13, 2005 | 07:16 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
carl, make sure you lube up the throttle linkage really well, then calibrate it again.
if it was sticking--even ever-so-slightly when we calibrated it last, then it returned to a rest position lower than that (or if you lowered the throttle stop), it'll show fault.
it's not a really big deal and won't effect anything when the car is moving. just recalibrate it and see what you can do about the play in the sensor.
Old Jun 13, 2005 | 07:39 PM
J-Rat's Avatar
Alcohol Fueled!
That is normal ops, and doesnt effect operation.
Old Jun 13, 2005 | 10:19 PM
Carl Byck's Avatar
Mad Man
I lubed the assembly(throttle linkage), and I had to relocate the throttle cable, due to some interference. It is only off by ~1*, so I think it s/b fine. Thank guys.
Old Jun 14, 2005 | 07:36 AM
C. Ludwig's Avatar
www.lms-efi.com
As the others have said this is normal and doesn't effect anything. If you back the idle adjustment screw out a half turn, recalibrate the TPS, then turn the screw back in it will show ~1% throttle instead of the fault code. Just something I do to avoid the annoyance of seeing FAULT.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Einheri
Oct 7, 2015 12:23 PM
