Sponsored by: CARiD
Intake Troubles
Old Jun 10, 2005 | 08:51 PM
Vert8813B's Avatar
Intake Troubles
Ok im looking for a suggestion but before that let me mention the whole story. If this has already been posted i apologize i just need help. I recently purchased the components to setup an air intake on my 1988 RX7 Vert. I was trying to put it on (what a bitch) got it on and then it would run but not idle. Obvious Vacuum leak. With the Aluminum Intake Tube i Had, it was causing a leak right up by the throttle body. I then said screw this aluminum and used the original rubber intake hose solved vacuum issue but then arised another problem.....by still having the stock intake box removed, i had no place to hook up the air pump hose. Its still disconnected and im running it like that. Wondering if i should drill hole in rubber intake tube to make hose fit. Or, eliminate hose and use a breather filter on the air pump inlet? Just dont want my rx7 baby dying prematurely :-) somebody please help Email is XWildHorses39X AIM is XwildHorses39X so give me so input please
Old Jun 10, 2005 | 09:36 PM
purple82's Avatar
Absolute Power is Awesome
Originally Posted by Vert8813B
Or, eliminate hose and use a breather filter on the air pump inlet? e
This one.
Old Jun 10, 2005 | 09:37 PM
Vert8813B's Avatar
thank you lol
connerfd3s
Sep 19, 2015 05:58 PM
