My speedo is broken, help
Old Jun 9, 2005 | 09:35 PM
1987_Gxl's Avatar
ALLyourRX7areBELONGtoUS
Ok i have a 87 gxl... you can see it in my avatar, its got the stock wheels & tire size I'm trying to figure out what my speed is at about 2.5-3k RPMs in 3rd gear.
if anyone could give me an estimate that'd be great
Thanks,
87_gxl
Old Jun 9, 2005 | 09:42 PM
KompressorLOgic's Avatar
I
my speedo broke too!
Old Jun 9, 2005 | 10:24 PM
rmriggin's Avatar
no clever remarks...
pick up a speedo replacement cable, if your speedo gear is still good you can feed a new cable through the housing.
Old Jun 9, 2005 | 10:51 PM
teeter's Avatar
i have a used s5 na speedo cable for sale. works great.
john
Old Jun 10, 2005 | 09:56 AM
1987_Gxl's Avatar
its an S4... I've just got S5 tails lol.... as long as the cable is no different from the one for an S4 I may be interested in buying it from you... to be exact with my issue it reads way over what speed i'm going, 60 mph its pegged at the M in mph, or 40mph reads 105-110mph, but its never the same
Old Jun 11, 2005 | 02:39 PM
1987_Gxl's Avatar
is it difficult to replace the speedo cable? would the dash need to be taken out? does this job take very long? I can't afford to be without my car for more than a day seeing as I have no alternative transport & I need to make it to work and home.
Old Jun 11, 2005 | 11:46 PM
RoyFifo's Avatar
Thanks,
87_gxl
Go to http://www.f-body.org/gears/ and enter the info on your wheels, trans gears and Rear Ratio. it will give you approximate speed for each gear in 100 RPM increments.
Old Jun 12, 2005 | 01:12 AM
dr.jones63's Avatar
It's a Hammer
Yes you have to remove the dash, no it isn't hard - 15 min job. It can come unclipped behind the dash very easily.
Old Jun 13, 2005 | 10:34 AM
jenkin's Avatar
tinea incognito
Ive got an extra cable that i could pull from an 88gxl. you can have the housing and cable...
pm me
Old Jun 17, 2005 | 03:31 PM
mazdapu's Avatar
If for some reason you do need to replace the cable, it only takes a few minutes to change. There is a seal inside the speedo drive gear. Chances are it has failed and feeding trans fluid up the cable and into the speedo head causing it to malfunction as you described. Hope this helps.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
