help! brake rotor advice
Old Jun 7, 2005 | 01:24 AM
EjCabrera's Avatar
last year i purchased some supposedly brembo rotors from ebay (never buy car stuff from there again). which to my luck they were probably mit (made in taiwan) replicas. these brake rotors suck becuase they rust up and make so much noise when braking. i was looking online for new rotors, the power slots and the rotoras. does anybody have any suggestions which is better or a different brand.
Old Jun 7, 2005 | 02:10 AM
maxcooper's Avatar
WWFSMD
Get some that are plated (zinc, cadmium) if the rust is a problem for you. I believe that PowerSlots are coated, Stillen sells coated, and a lot of other places do, too.
-Max
Old Jun 18, 2005 | 07:23 AM
Pat McGroin's Avatar
Sushi ******!
I would buy an actual set of Brembo blanks from an authorized Brembo vendor.
No reason to run slotted or cross drilled, unless you want the looks.
Old Jun 18, 2005 | 05:29 PM
maxcooper's Avatar
WWFSMD
I like the Brembo blanks, too, but they don't come plated from Brembo. I bet there are shops that sell coated Brembos, though. Or you could get a set and have them plated.
Brembo has a part number for rear rotors, but I don't think they actually make them. You'll have to get a different brand for the rear.
Pat McGroin
-Max
Old Jun 18, 2005 | 06:49 PM
ma71supraturbo's Avatar
Powerslots are coated and work very well for me.
Old Jun 19, 2005 | 10:09 PM
emopunk96's Avatar
Id go with the powerslots. Everyone I have talked to loves them. And as they said Brembo does not make the rotors you are talking about, and are not sloted, which sloting and drilled is usually worthless anyways
Old Jun 20, 2005 | 12:18 AM
I like slotting -- evacuates water, has more surface area for better heat dissipation, they don't crack like cross-drilled, and they clean off the top layer of the brake pad nicely...
Marty RE
Aug 13, 2015 11:19 AM
