Microtech lt8 spark problem
Old Jun 6, 2005 | 10:11 AM
remtec76's Avatar
Rotor Head
lt8 spark problem
I have an lt8 the car was running good and it just stop running when i checked it the trailing coils where not fireing when i put the computer on test mode it fires the coils so i thought the cas went bad,swaped it and still no fire any ideas.thanks T.
Old Jun 6, 2005 | 04:55 PM
Crusader_9x's Avatar
Are your leadings sparking? Just losing trailing spark wouldnt cause the car to not run.
Old Jun 7, 2005 | 04:51 PM
I F****D a mermaiiiid
time to pull out the trusty multimeter.
check the CAS wiring at the point it terminates at the computer. make sure that all of your connections are still in good shape. all joints should be soldered with good penetration either shrink wrapped or e-taped. efforts should also be made to isolate soldered joints from flex and vibration. check all of your ignition coil wires (power and signal) for continuity as well.
while cranking the vehicle check to see if there is a blinking red light on your microtech. if ther is then there is a fault code stored. boot up your software or your hand tuner and find the error check screen. this is all well documented in the instruction manual and the screens are all self explanitory.
Ray
Old Jun 8, 2005 | 08:26 PM
remtec76's Avatar
Rotor Head
thanks for the advice checked with multimeter all conections are good but the had peice reads rpm err,ref err,so i put my friends cas on and still read the same.
Old Mar 26, 2009 | 01:01 PM
First gen man's Avatar
yessir
I have a similar problem, with the lt 10s. I have no leadings most of the time, with the rear leading firing every now and then. Sometimes perfect for a few minutes. Engine still starts and runs, but it's firing only on trailings.
Wiring is good to all coils, and wiring from the CAS is correct, no err codes. Also all the coils are functioning. Tried 2 different crank angles.. Why just the trailings?
Old Mar 26, 2009 | 06:42 PM
rx72c's Avatar
Top Answer: 1
Ok now.
FIRST GEN MAN. Make another thread so i can post in yours and not confuse the other dude.
as for the original problem.
When a car dosnt start.
First thing to check IS.
Is the microtech green light on while cranking and on ignition?
If yes. Great.
Now check if the ORANGE light is flashing on crank?
Answer these two questions. then we can go from their.
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
Microtech
Nov 21, 2015 10:20 AM
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
