N/A fireball?
Old Jun 4, 2005 | 03:15 PM
JSmith0101's Avatar
Play Well
N/A fireball?
How is it you guys get the fireball to shoot out of your exhuast? I always read about it, but I can't seem to do it, but I guess I can't really get out and look, either. I know it's a really stupid question, but I care about my car too much to do something that won't work. If it works, I'll do it... wow, that's *** backwards.
Also, is a base model 87 N/A good at whipping around, say, on a big, open, flat piece of concrete, and smoking 'em? I've got some tires that are no good, and I want to have some fun before I get new ones.
Old Jun 4, 2005 | 03:41 PM
Syonyk's Avatar
Well, a fireball is a result of unburned gas departing the tailpipe at high temperature and igniting when it finally gets oxygen.
If you have your catalytic converter, you probably won't get much of a fireball (though I understand it is doable). If you have a properly tuned standalone, you probably won't get any fireball (since you won't be running stupidly rich).
With the stock ECU, run at high RPM/load for a while (running 5-7k RPM, high throttle settings) to heat up the exhaust system, and then just accelerate and let off. I've throw some impressive fireballs that way (usually not intentionally), and one of them was bright enough that my passenger whipped around to look for the cop (he thought it was a spotlight).
I'll eventually be getting a standalone and tuning this "feature" out of my car.
As for tires, you have an open differential, so you'll mostly be a "one wheel wonder", but you can definitely roast off some tire rubber.
-=Russ=-
Old Jun 4, 2005 | 03:47 PM
88rxn/a's Avatar
tom port.. AKA streetport
i have a gtu with an lsd an shitty tires just begging me to burn them off...........
Old Jun 4, 2005 | 03:55 PM
frigidmonkey's Avatar
rotor withdrawal
I brought my vert home today with no exhaust except for the manifold itself, it threw some serious flames when I took it up to redline and shifted :P little scary having that happen under the car though. I couldnt see them but my gf was following me and totally freaked out :P
Old Jun 4, 2005 | 04:01 PM
88rxn/a's Avatar
^ nice!!! fire rocks!!
Old Jun 4, 2005 | 04:23 PM
JSmith0101's Avatar
Play Well
So doing doughnuts is a no-go? I've roasted my tires before, I want to do a doughtnut, I couldn't think of the word.
Old Jun 4, 2005 | 04:30 PM
ViperBart's Avatar
Compression King
I have videos of me doing doghnuts with my stock '86 N/A in a parking lot.
I dont see where the problem is here?
Old Jun 4, 2005 | 04:37 PM
Grentai's Avatar
ah, barrel O' crabs..
haha they're saying that the problem is that he will only be roating one tire.
Old Jun 4, 2005 | 04:54 PM
ViperBart's Avatar
Compression King
I also find that funny... but I dont have an lsd and it still launches with 2 strips of black rubber and it fishtails when i give it the gun shifting in second in a turn... dont get me wrong.. its not lsd... but you can still smoke em.....heck if it doesnt smoke em in right handers... try lefties hahaha
Old Jun 4, 2005 | 04:58 PM
JSmith0101's Avatar
Play Well
Smoking is no problem, I just want to do doughtnuts.
Old Jun 4, 2005 | 05:04 PM
ViperBart's Avatar
Compression King
I see, I see... I guess my friday's purchase of an 88 GXL (with lsd) is a really good thing afterall I will see next week when I have insurance, inspection, my suspension and exhaust swapped out of my current 86 onto that one.
Old Jun 4, 2005 | 05:11 PM
JSmith0101's Avatar
Play Well
Can you do doughnuts with an open diff? I know it's a dumb question, but I'd rather not try if I can't.
Old Jun 4, 2005 | 05:17 PM
ViperBart's Avatar
Compression King
wanna see the video? message me @ viperbart at msn dot com
Old Jun 4, 2005 | 05:27 PM
JSmith0101's Avatar
Play Well
Thanks.
Old Jun 4, 2005 | 05:57 PM
Angel Guard Racing Team's Avatar
Take the car up to about 4000 RPM and let go of the gas, the fireball should come out at around 2000 RPM...
rxlevi7
Sep 26, 2015 07:28 AM
mulcryant
Sep 9, 2015 05:24 PM
