Oil coolers?
Old Jun 4, 2005 | 11:56 AM
baddassTurboII's Avatar
Oil Nozzels/Injectors
What tool do I need to take the oil coolers off the engine?Wrench seems to be too thick.
Old Jun 4, 2005 | 12:08 PM
mmm... I got the same problem as you, but since I just removed them I used a pair of vicegrip.
I dont know if it can damage something internally though....
Old Jun 4, 2005 | 12:12 PM
Turbo II-FB's Avatar
open bos wrench I thing its a 23 or 24mm
Old Jun 4, 2005 | 12:14 PM
When I took them off the intake manifold I used a 14mm wrench..But on the engine it seems too big.
Old Jun 4, 2005 | 12:53 PM
with the engine make a 2ft braker bar and get some wd40 and spray it and let it sit.. THen undo it. The next thing is geting the lines off the actual cooler and just do the dame thing and they should come off
Old Jun 4, 2005 | 02:46 PM
Jaiyurai's Avatar
Endure Persevere Succeed
What does the oil cooler have to do with the INTAKE MANIFOLD??
There's only 4 small nuts on the oil cooler frame which are 10mm I believe.
Then there's the oil feed and oil return lines. One's on the front cover which I used a crescent wrench. The other is under the car around the oil pan. I cant remember off of my head but i think its a 24mm.
Old Jun 4, 2005 | 03:55 PM
Im was talking about the oil injectors.,I had them mixed up,sorry
Old Jun 5, 2005 | 02:05 AM
Jaiyurai's Avatar
oh ok. The oil onjectors might be a little trickier. I think they're bigger than a 14mm. Since the oil injectors are angled in a way you can't really use a socket wrench. I'd spray them down with WD40 or PV blaster, wipe, then use a crescent wrench on them. That should be plenty enough to get them out.
Old Jun 5, 2005 | 08:32 PM
I took a 14 mm and had it shaved and was able to get them off,I know they said to get them new but I found some at the u pick your part and used those.They was off of a n/a turbo.They seem to fit fine,Will I have any problems with this?
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
