HKS peak boost gauge wiring/hose info needed
Old May 18, 2005 | 01:00 PM
EFI-TR8's Avatar
Geek / Gearhead
Question HKS peak boost gauge wiring/hose info needed
I just got an HKS peak/hold boost gauge and I need some info on the wiring and hose connections.
Some of the wiring is obvious, but I'm not sure about two wires:
black = ground
yellow = backlight
red = battery-positive(?)
orange = ???
Also, it has three vacuum line nipples... anyone have any idea why it would have more than one, and what the other two are for?
I can't read Kanji, or this wouldn't be an issue.
I looked on http://hksusa.com/ and it looks like they don't even list this unit any longer. I couldn't find an email address to contact them, and I'd rather not bother them on the phone for a product they no longer manufacture (last resort).
Old May 18, 2005 | 07:17 PM
EFI-TR8's Avatar
Geek / Gearhead
In case anyone is wondering: (and in case anyone stumbles over this with a search later)
Black = ground
Red = switched hot
Orange = unswitched hot
Yellow = backlight hot
...and for the sensor:
Blue = IN (signal)
Green = G (ground)
Yellow = 5V (out)
Oh, and what looks like vacuum hose nipples are actually the strangest banana plugs I've ever seen.
Old Aug 23, 2005 | 01:46 PM
sleeperfc's Avatar
MP T-70 = Fun
i hooked mine up using this color code... and the needle bottoms out to the bottom of the vaccume side. ummm weird.
are you sure this is right? where do i ground the green? does it matter?
