Microtech some more fuel pump help.
Old May 16, 2005 | 07:01 PM
Sir Rupert Hobo's Avatar
seven-less
so i tried to start the car today for the first time. no go. why? cause i'm not getting any fuel pressure. none. i looked over my wiring and looked over it again. when i turn the key off the fuel pump relay clicks once, same thing when i turn it on.
i took out the pump to make sure everything looked good. everything is fine. i check to see if the ground was good, yup.. i'm getting a 12v ignition/12v from the battery at the relay.
why am i not getting any pressure? the fuel lines at the pump are still bone dry. the motor is turning over, just can't start it without any fuel...
is the relay dead? the pump?
it's a walbro..
Old May 16, 2005 | 08:55 PM
stacher's Avatar
You said "I am getting a 12v ignition/12v from the battery at the relay". If lines are bone dry, 3 things can be happening.
1. You are not getting 12v at the pump. (check that the pump is coming on. Use
a meter or listen carefully for a winding noise when it comes on) Bad relay or
broken wire.
2. The pump is bad. (Run a 12v wire from the battery to the pump while the
pump is grounded. If it doesn't come on the pump is bad)
3. The pump is sucking air and not gas. (if the pump is good, make sure the
intake side of the fuel pump is sumerged in the gas).
Something else to check........the intake and return fuel lines(going to the rails) are connected correctly.
As for the clicking noise on the relay......that usually is normal. It gets energized when current gets to it and "unenergized" whe n current is taken away.
Old May 17, 2005 | 01:12 AM
FC_mania's Avatar
u should be able to hear some whirring sound when your keys is at ON position ......then after the whirring sound stop (fuel pump) then only i start the car........
Old May 18, 2005 | 09:22 PM
seven-less
thanks for the replies!
it was #1... there was a wire that was cut, it was the main power wire.. doh!
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
