Midpipe
Old May 11, 2005 | 10:53 PM
mendozam's Avatar
95R2
Question Midpipe
Does a midpipe cause boost creep in a RX7
Old May 11, 2005 | 11:00 PM
littlemilla3's Avatar
yes
Old May 11, 2005 | 11:01 PM
Larz's Avatar
Potato Love
And gas fume smells. And lots of noise.
Old May 11, 2005 | 11:25 PM
mendozam's Avatar
95R2
What setup can I do to get full boost while still having a midpipe
Old May 11, 2005 | 11:28 PM
Narfle's Avatar
Rx7 Wagon
when we find a cake you can have AND eat we will let you know
Old May 12, 2005 | 12:27 AM
rynberg's Avatar
You can port the wastegate (search for how-to). This usually reduces the problem enough so it can be dealt with.
What are your other mods?
Old May 12, 2005 | 02:12 AM
MR_Rick's Avatar
Planning my come back
beside what Rynberg said, a good EBC like Greddy Proffec B will help also
Old May 12, 2005 | 08:24 AM
RochX7's Avatar
As long as you reliably keep your Psi at stock levels (10psi) you should be able to hold a midpipe..
Old May 12, 2005 | 09:28 AM
Hyperite's Avatar
Vagina Junction
Wha? Boost creep means you CAN'T reliably keep your psi at stock levels.
Also, a midpipe doesn't CAUSE boost creep, a restriction in the exhaust (cat) will not ALLOW creep. For example, if you have a stock pre-cat, catback, intake, intercooler, and a full midpipe, you probably won't get boost creep because of the bottlenecks elsewhere in the system. It just so happens that the catalytic converter is often the largest restriction and last-ditched component of the intake/exhaust setup.
Old May 12, 2005 | 12:32 PM
zullo's Avatar
Obsessed
Just trace a 3" exhaust gasket on a small sheet of stainless and cut it out, but make the hole 2.5" instead of 3". Insert it between mp and cb alongside the gasket.
It works just fine for me to control creep and will stay in place until I have time to port the wastegate.
