What is the best apex seals made for the 93-95 RX-7!
Old Jan 2, 2002 | 01:11 PM
AARotary's Avatar
Question What is the best apex seals made for the 93-95 RX-7!
Whose make the best apex seals available for 93-95 RX-7. What is the seals of choice 2mm or 3mm. I am planning to run 18psi and my goal is to make 400+rwhp. What is everybody using in theirs 13B-REW.
Old Jan 2, 2002 | 01:26 PM
Bacon's Avatar
IRS 4 Life
stock 2mm is what im gonna be runnin..im shootin for 500+@ 20-22psi
mabe more who knows
hurleys are nice b/c if u pop it they are *suposidly wont kill turbo* softer, wich makes them seal better but also wear faster...
ceramic is nice but$$$$$$$$ not that that matters to u but if u detonate they all go...
3mm will take detonation better than 2mm but the problem is getting the rotors milled properly fot the 3mm seals, seems from what ive researched there is some trouble getting consistent and well machined rotors...
Old Jan 2, 2002 | 01:37 PM
neo_omega's Avatar
***Moderator***
Scoot Sport seal. They have a 600 hps FD.
Old Jan 2, 2002 | 01:55 PM
AARotary's Avatar
Neo Omega;
Do you know what kinda seals Scoot is using for their 710ps FD maybe that is what I want but how can I get a hold of it. That Scoot sport seals is it 2mm 0r 3mm.
Old Jan 2, 2002 | 02:08 PM
neo_omega's Avatar
***Moderator***
Originally posted by AARotary
Neo Omega;
Option 2 just dyno that car. Just have 600 rwhp
The name is NB Apex Seal. My RX-7 parts book is at home now. Don't know it's a 2mm or 3mm, but it can take 600 rwhps. Do you care?
Old Jan 2, 2002 | 05:13 PM
BlackR1's Avatar
Meesto Spakaro
I've heard a lot of conflicting conflicting information about apex seals...from what I've gleaned, you'll be fine running a stock 2 piece 2mm seal. Stock seals can handle a lot of boost, just not detonation...no seals can help with that. I think you should just stick with the 2mm's and just get the car properly tuned.
Old Jan 2, 2002 | 10:53 PM
zayrx7's Avatar
the mazda zoom zoom store
would carbon fiber work as seals, since it would be more durable.
Old Jan 3, 2002 | 12:44 AM
BlackR1's Avatar
Meesto Spakaro
carbon fiber seals? hehe it'd look pretty i suppose Actually, Mazdatrix does sell carbon seals...never heard much about them though
whatever happened to those Carbon Fullerene seals?
Old Jan 3, 2002 | 12:54 AM
JoeD's Avatar
its not about the seals...its about the tuning. you have 5mm seals if you want. if the car is tuned incorrectly, youll blow those too! stock seals could take all the abuse 3mm ones can take knowing that the car is tuned correcly. do a search on this. this debate is almost as big as the FMIC vs. SMIC war and sythetic oil vs. dino debate.
Old Jan 3, 2002 | 01:19 AM
Nathan Kwok's Avatar
My dream engine would have 2mm Ianetti ceramic seals for their superior wear qualities and lighter weight. You don't need 3mm seals with 18psi, and 2mm seals better. Of course, if you bust ceramic seals, say goodbye to the rotor housings, but you're not going to do that cause you're going to tune the car very carefully, right?
Old Jan 3, 2002 | 02:13 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
Don't forget if you have a single it (ceramic seal) will take a piece of the exhaust turbine with it too
Th0m4s
Feb 26, 2019 02:04 AM
Clubuser
11
Aug 31, 2015 12:25 PM
sYnth.
Aug 19, 2015 06:27 PM
