removing throttle body coolant lines
Old May 5, 2005 | 06:27 PM
red fd3g's Avatar
Question removing throttle body coolant lines
what are pro to removing the coolant lines besides maken it lookclean
clean
Old May 5, 2005 | 07:07 PM
4CN Air's Avatar
DETH TRP
pros:
marginally cooler intake temps
less coolant lines
cons:
possible issues in very cold weather (but who drives their 7 in the winter anyway)
Old May 5, 2005 | 09:38 PM
GARCO MOTORWORKS's Avatar
You remove 3 rubber hoses and 6 clamps .All good places to leak . I put pipe plugs where the nipples were or if the water pump houseing is off ,that hole is welded closed and smoothed out .I also make a plate to cover the holes where the hot wax rod was .I cut off the shaft for the cam and remove all that junk .Clean clean Plus you no longer have to adjust it . Cold start is no problem with the Power FC .
CaptainKRM
14
Aug 26, 2015 09:52 PM
86glxNA
Aug 22, 2015 08:54 PM
