1600cc secondaries+connetors?
Old May 5, 2005 | 11:41 AM
Faster Is Faster's Avatar
Do I need connectors for these fuel injectors?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Are those good injectors? If they are is the price right?
Old May 5, 2005 | 01:04 PM
no, I dont think you're gonna need connectors.
I bought those same injector and the clip looks exactly the same
you're gonna have to modify them to fit though...
here's the link : http://home.mn.rr.com/linnihan/1600c..._injectors.htm
have fun
l-p
Old May 6, 2005 | 11:59 AM
Are there injectors for sale that doesn´t need modification? Or what way would be the easiest way if modification is needed. The way shown in the link or connector way?
Old May 8, 2005 | 04:46 AM
anybody?
Old May 8, 2005 | 12:06 PM
Wankel7's Avatar
Haven't we ALL heard this
Uh,,,,, the link above your post is clearly the injector modification. Did you look at it?
Ok , here is how it works.
1. Yes, you need to modiffy the injector to work with a stock fuel rail.
2. Yes, you will need to buy the injector electrical harness connnector because your stock connector will not work.
I bought my 1680s from that vendor you linked us to on ebay.com
However, I wish I bougth from here.
http://kgparts.com/newfuel.htm
Reason being it is cheaper and it COMES with the connectors. Also, KGparts is a RX-7 guy so ...that is cool.
James
Old May 8, 2005 | 12:09 PM
billzrx7's Avatar
the electrical connectors can usually be found at local automotive parts stores ranging in price from $5-13 bux.. and to amke the 1680cc injector fit in the stock rail the top 1/4-1/2" of plastic surround needs to be removed so the stock seat and a proper sized O-Ring can be matched together for a tight seal.
Old May 8, 2005 | 04:39 PM
Wankel7's Avatar
Man, that cat is in finland.....don't know about all that
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
