Sequential turbos
Old May 5, 2005 | 12:32 AM
turbine's Avatar
Sequential turbos
do Sequential turbos spool together or does one kick later then the other
Old May 5, 2005 | 12:40 AM
TT_Rex_7's Avatar
One turbo spools, then the second one kicks in at 4,500 rpms. This is the why there is a "dip" in the boost pattern. (10-8-10) With a non-sequential setup, both turbos spool together.
-Alex
Old May 5, 2005 | 12:46 AM
turbine's Avatar
what would cause the second one not to kick in?
Old May 5, 2005 | 12:47 AM
TT_Rex_7's Avatar
There's a million and a half reasons why the second one may not kick in. Are you having a problem with the second turbo not kicking in?!
Oh, try searching next time!
-Alex
Old May 5, 2005 | 01:18 AM
turbine's Avatar
-Alex
gee i guess thats why i asked
oh yea i forgot to search again oops you Arrogant ...
thanks for your help
Old May 5, 2005 | 01:21 AM
turbine's Avatar
just give me the first couple hundred reasons
Old May 5, 2005 | 01:44 AM
TT_Rex_7's Avatar
Maybe you could start by telling us what's going on you jackass. How the hell are we supposed to help you when all you ask is how the sequential system works?
Oh, BTW, learn how to search.
-Alex
Old May 5, 2005 | 02:04 AM
tahmid's Avatar
cursed 7
All you need to and more.....
http://www.autosportracetech.com/RX-...leshooting.htm
http://rx7.voodoobox.net/howto/solen...oid_check.html
Old May 5, 2005 | 05:58 AM
dgeesaman's Avatar
In case you're curious how the system is supposed to work...
http://davidgeesaman.com/rx7/TwinTurbo.PDF
http://davidgeesaman.com/rx7/Mazda_S...ual_Turbos.PDF
Where I would look, in order:
- Tear in intake hose coupling (between the turbos and intake elbow) - remove each and turn inside out, looking for a small leak
- System holds vacuum and pressure without leaking
- Correct vacuum and pressure going to the TCA at exactly 4500rpm
- CCA opening at 4500rpm
If you don't have a pressure and vacuum Mityvac tool, now is the time to buy one.
Dave
Old May 5, 2005 | 09:35 AM
turbine's Avatar
Dave
thanks
Queppa
Nov 18, 2024 03:47 AM
streetlegal?
Mar 17, 2022 02:46 PM
Skeese
65
Mar 28, 2017 03:30 PM
rxmiles
Aug 24, 2015 02:07 PM
