Quick question for anyone who has installed a Pettit SS DP
Old Jan 1, 2002 | 09:32 PM
az_lynx's Avatar
Question Quick question for anyone who has installed a Pettit SS DP
It comes w/ 3 double threaded lugs and nuts and 1 hex bolt. Where does the hex bolt go if looking at the layout from the passanger fender. Also should I install the new O2 sensor before I install the pipe or will I have room after?
tia, chris.
Old Jan 1, 2002 | 10:23 PM
unvmyrx7's Avatar
towards the back on the bottom.
Old Jan 1, 2002 | 10:24 PM
az_lynx's Avatar
By back I suppose you mean back of the car? so looking at the pipe from the passanger fender the lower left? tanx..
Old Jan 1, 2002 | 10:26 PM
unvmyrx7's Avatar
correct, u will need a large allen key
Old Jan 1, 2002 | 10:27 PM
az_lynx's Avatar
thanks again...
Old Jan 2, 2002 | 06:24 AM
bajaman's Avatar
Constant threat
Seem like I remember wondering that, and finally test fit the allen head bolt in each hole, and noticed the one that had the least clearance from the flange to the pipe and used it there.
And I would definitely put the O2 sensor in BEFORE you install the pipe!
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
