Power FC Single Turbo---PFC Check Engine Light
Old Apr 28, 2005 | 08:59 PM
Hugh Sperry's Avatar
Since all but four wires going to the ECU are used, (or at least still plugged in) will you get a check engine light if you remove the now useless solenoids?
If so what wattage resistor is required? It seems I've read in a post some where to use a 300 ohm 1/2 watt; yet when checking resistance across the solenoid coil, it is on average 32 ohms.
Old Apr 28, 2005 | 09:24 PM
DaleClark's Avatar
RX-7 Bad Ass
The PowerFC could care less about the various emissions solenoids. As long as none of the key sensors (TPS, CAS, water temp, etc.) are bad, it's all happy with it.
Dale
Old Apr 28, 2005 | 09:30 PM
rynberg's Avatar
As Dale said, you no longer need resistors for removed solenoids. The PFC does not use the check engine light to indicate codes, it uses it to warn about high knock readings. It also uses your exhaust overheat light to warn about missing/bad sensor data.
Old Apr 30, 2005 | 02:08 AM
BlueSprite's Avatar
how can i solve the knock problem, if i have an issue about knock when reving ?? need some one to do dyno tune ??
BTW: once i have PFC, i dont use the jumper to check on the codes any more ??
Old May 3, 2005 | 10:22 PM
powermalex's Avatar
rynberg
My check engine light does not come on anymore when I turn the key.
I just installed my new PowerFC. Is that normal?
Old May 3, 2005 | 10:33 PM
rynberg's Avatar
Originally Posted by powermalex
rynberg
Yes it is.
Kyo
Apr 13, 2019 09:24 AM
sherff
Feb 24, 2019 12:09 PM
