New guy / turbo dummy
Old Dec 31, 2001 | 09:18 AM
EProdRx7's Avatar
How much boost should I be making? Everything is stock no mods YET! But I would like to get a base line and work from there. The stock guage go about half way up the scale or just a bit over under full load.
Also should my car be making boost when it is not loaded? The factory manual seems to imply that it should but I was told that it shouldn't ???????????
Old Dec 31, 2001 | 09:22 AM
Greg's Avatar
Re: New guy / turbo dummy
On the FD i believe the boost is : 10 lbs - 8lbs - 10 lbs. on the FC turbo stock we make around 6-7 lbs boost.
Old Dec 31, 2001 | 10:22 AM
MeLoco's Avatar
Take the time to look on this site it is more than useful for just about anything you need to know.
http://www.scuderiaciriani.com/rx7/
Here is another one.
http://www.rx7turboturbo.com/robrobi..._to_engine.htm
On the FD your boost pattern should be 10-8-10 the slight drop is due to the transition.
Hope that helps
cristoDathird
28
May 30, 2019 08:47 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Clacor
Aug 14, 2015 09:17 AM
